Can Quantum Entangled particles convey information faster than speed of light. If they don't what was wrong with John Bells experiment?
Satwik
  • 291
You cannot convey information faster than light using quantum entanglement. For a mathematical proof of this result, which is commonly called the "no-communication theorem", see e.g. https://en.wikipedia.org/wiki/No-communication_theorem.
Nothing was wrong with Bell's experiment. Communication was not demonstrated, only correlation between outcomes. In order to derive information from correlation, you either have to:
  • Compare the results of experiments on one particle with experiments on the other, which requires communicating the results of both experiments classically (i.e. slower than light), or
  • Know beforehand exactly how the entanglement is set up, in which case information wasn't really communicated using the experiment at all; once you measure your particle, you know what state the other particle is in, but you already knew that, conditionally (just like you already knew what the other particle's state would be for every other experimental outcome), so it's more a case of selecting a relevant piece of information than actually communicating anything.
If neither of these conditions is fulfilled, and you just look at the results from one of the particles, then you'll just see randomness. Importantly, you can't actually control the outcome of the measurement; this is one of the basic postulates of quantum mechanics.
