22
Let's say we have an electron around atom. Let's say the electron drops into a lower electron shell. Is 100% of the energy difference converted to a photon? Does the atom recoil at all? Is the any of the energy lost to any other means?
There is always energy loss due to recoil. Considering a single atom that is in free space, the total momentum is conserved, and the total reaction energy is constrained by the transition energy $E_0$ (ignoring the natural line width due to the energy-time uncertainty), so we get in the centre of mass frame: $$0 = \hbar k + mv $$ $$E_0 = \frac 1 2 mv^2 + \hbar \omega = \frac 1 2 mv^2 + \hbar c k$$ Leading to the equation $$E_0 = \frac {\hbar^2 k^2}{2m} + \hbar c k.$$ So $$k = - \frac{mc}{\hbar} \pm \sqrt{ \frac{m^2c^2}{\hbar^2} + \frac{2mE_0}{\hbar^2} } = \frac{mc}{\hbar} \left( \sqrt{1 + \frac{2E_0}{mc^2}} - 1 \right) \approx \frac{E_0}{\hbar c} - \frac 1 4 \frac{E_0^2}{\hbar mc^3}. $$ This corresponds to an energy correction for the photon of $$\frac{\Delta E}{E_0} = -\frac{E_0}{4 mc^2}.$$ So the relative correction is of the order of the transition energy compared to the rest energy of the recoiling mass.
If the atom interacts with other atoms (and is not in free space) the process becomes complex and energy may be transferred to the interacting objects (e.g. in a crystal lattice) the possible recoil energies are determined by the phonon spectrum, here, at low temperatures, the Mößbauer effect becomes important wherein the recoil momentum is transferred to the entire crystal, leading to a virtually recoil free emission (since the reaction mass is macroscopically large).
Further, there are other ways an electron can loose its energy – e.g. in Auger processes another electron is ejected from the atom, or the energy can be transferred ("coherently") to another atom (exciting an electron there). Further, combination processes, such as emitting a photon and ejecting an electron are allowed if all quantum numbers are conserved.
Sebastian Riese
  • 13,484
  • 44
  • 64
It depends on the reference system used.
In the center of mass of the excited atom, momentum concervation should assure that the photon and the atom have equal and opposite momenta, so that will diminish the energy taken by the photon. The mass of the nucleus though is so much larger than the ev transitions of the electons that in effect the center of mass is the same as the rest frame of the nucleus.
The energy levels have a width, thus there is a probability of a photon with a smaller or higher frequency than the average of the energy level should appear.
Have a look here for a discussion of broadening of lines due to the motion of the atoms, and also the doppler shift in spectra due to the motion of the source or the detector.
It all depends on the frame of reference.
anna v
  • 236,935
If there are only two levels involved and the atom transitions entirely from the excited state down to the ground state then yes, all of the energy that was stored in the electron excited state (this energy was in the form of the electron's kinetic energy and potential energy due to being further away from the nucleus on average) is converted into a photon, i.e. into electromagnetic field excitation.
When this happens yes, the atom does recoil due to the momentum carried away by the electromagnetic field. This is a key part of the principle behind Doppler cooling of atomic clouds down to microkelvin temperatures.
Note that in many cases (spontaneous emission for example) the photon is not emitted in a single direction but is rather emitted radially in many directions. This is a little weird to think about and can lead to confusion. Here is how you should think about it. When the atom decays to the ground state it creates an electromagnetic field pattern similar to that of a dipole antenna (i.e. outgoing radially). However, this whole electromagnetic field pattern only contains 1 photon. The natural question then is 1) what is the momentum of the photon and thus which direction does the photon recoil? The answer is the dipole pattern should be thought of as the photon being in a quantum superposition of having been emitted as a plane wave in many directions at once (note that a dipole pattern can be decomposed into plane waves). Thus, the atom also becomes in a superposition of having recoiled in many directions at once. If you put photon detectors all around the atom then you will see that only one of the detectors clicks. If the detector to the right of the atom clicks then you will see that the atom recoiled to the left. If the detector to the left of the atom clicks then you will see that the atom recoiled to the right.
When considering an atom the energy can either be electronic or photonic. That is, all of the energy is either in the EM field or with the electron. The system can be in a variety of superpositions of having the energy in different places but there aren't other options. If instead of considering an atom you consider a molecule then there are now vibrational rotational configurations of the nuclei involved which can store energy. In this way energy can be lost to relative motion of the nuclei rather than held purely in the electron configuration or the electromagnetic field.
Jagerber48
  • 16,234
