From here and here I know the commutation relation for two operators are:
$$\left[f(A), B\right] = \left[A, B \right]\frac{\partial f}{\partial A}$$ if $\left[A, \left[A, B \right]\right] =0$ and $f$ is a reasonably behaved function.
What does $\frac{\partial f}{\partial A}$ mean? How can I differentiate with respect to an operator?
zabop
  • 607
  • 16
Formally, you treat the operator as if it were a variable.
It works because functions of operators are usually defined by their Taylor series. If we plug that into the left side, the problem reduces to calculating $[A^n, B]$ (since the commutator is a linear operation). By repeatedly using $[AB,C]=A[B,C]+[A,C]B$ we find $$[A^n,B] = \sum_{k=0}^{n-1}A^k[A,B]A^{n-k-1}.$$ Now if $[A,[A,B]]=0$, as you write, we can switch all $A$ to one side and get $$[A^n,B] = \sum_{k=0}^{n-1}[A,B]A^{n-1} =[A,B]\,n A^{n-1}$$ which on the right is exactly the usual rule for differentiation with respect to $A$, if $A$ was a variable. So for the purpose of calculating the original commutator, you can just treat it as if it was a variable and derive with respect to it. Careful though whenever $f$ is a function of multiple non-commuting operators.
noah
  • 10,404
  • 29
  • 39
