In the theory of phase transitions, an order parameter is usually defined as some quantity which distinguishes the two phases of the system by being zero in one phase, and non-zero in the other (see e.g. this and this question). This definition has always confused me since it seems like a very broad definition. The same phase transition may be studied through many distinct quantities acting as the order parameter. This question also discusses this non-uniqueness, however, without any conclusive answers.
Now even though this confused me a bit, I never thought there would be an actual problem with having this broad definition. But then I saw people talking about the order parameter critical exponent. At first I thought that maybe the critical exponent of the order parameter is unique, even though the order parameter itself is not. However, this is clearly not the case.
Let $M(t)$ be a valid order parameter of some phase transition, where $t\equiv \frac{T-T_c}{T_c}$ is the reduced temperature. Since it's an order parameter, $M$ is identically zero in one phase (e.g. $t\le 0$), and non-zero in the other. By definition, for any function $f(M)$ which has only one root at $M=0$, the quantity: $$M^*(t):= f(M(t))$$ also completely satisfies the definition of an order parameter. At $t\leq0$, $M^*=f(0)=0$, and at $t>0$, $M^* \neq 0$; since $M\neq 0$, and $f$ doesn't have any roots other than the origin. Now near the transition $t \to 0$, $M \propto t^\beta$, where $\beta$ is the order parameter critical exponent. Using a Taylor expansion, the behavior of $M^*$ near the transition is: $$M^*(t)=f(M(t))=f(A t^\beta)=0+f'(0)At^\beta+\frac12 f''(0)At^{2\beta}+O(t^{3\beta})$$ Now if $f'(0)\neq 0$, everything works fine and the critical exponent for $M^*$ is the same of that of $M$. However, when $f'(0)=0$, the critical exponent of the two order parameters will be different.
For example, for the mean field theory result of the Ising model, if $M \sim t^{1/2}$, then another order parameter defined by the square goes like $M^*:=M^2 \sim t^{1}$. In my opinion, there can only be two possible resolutions to this problem:
- The order parameter, and indeed its critical exponent are both not uniquely defined, and when people talk about the order parameter and the critical exponent, they implicitly assume that everyone they're talking to has the same particular quantity in mind.
- There is a more specific and restrictive definition for what an order parameter is, that me (and apparently many others) don't know about.
It would be great if someone could tell me which one is correct!
