Chemical potential is defined as the change in energy due to change in the number of particles in a system. Let we have a system which is defined by the following Hamiltonian: $$H = -t \sum_i^L c_i^\dagger c_{i+1} + V\sum_i^L n_i n_{i+1} -\mu \sum_i^L n_i$$ where $c^\dagger (c)$ are creation (annihilation) operators, $n$ is number operator, $t$ is hopping parameter, $V$ is nearest-neighbor interaction, $L$ is the total number of sites and $\mu$ is chemical potential.
What I understand by chemical potential is, if we set $μ=$some constant, then no matter how many sites ($L$) we add to the system, the number of particles will always be conserved. (Please correct me if I am wrong)
QUESTION:
What is the relation between chemical potential and the number of particles? i.e. if I set $μ = 10$ then how many particles are allowed in the system?
Sana Ullah
  • 861
  • 19
At zero temperature, to find the relation between $\mu$ and the particle number you have to know the ground-state energy $E_N$ of the system with $N$ particles, and then $\mu= E_{N+1}-E_N$ Consequently you have to solve your Hubbard model exactly before anything else.
Once you have done this, you can approximate the definition of $\mu$ as $$ \mu = \frac{\partial E}{\partial N} $$ (where $E=E(N)=E_N$) and from this obtain $N$ as a function of $\mu$ by means of Legendre transformation. Set $$ \Phi= E-\mu N $$ Then $$ \frac{\partial \Phi}{\partial \mu} = \frac{\partial E}{\partial\mu} -N-\mu \frac{\partial N}{\partial \mu} $$ $$ =\frac{\partial E}{\partial N}\frac{\partial N}{\partial\mu } - N- \frac{\partial E}{\partial N}\frac {\partial N}{\partial \mu} $$ $$ = -N $$
At finite temperature a thermodynamic system with a fixed chemical potential must be in a grand canonical ensemble and therefore free to exchange particles with a reservoir. Consequently the particle number is not fixed but instead its average $<N>$ is determined by $$ <N> = - \frac{\partial \Phi}{\partial \mu} $$ where now $$ \Phi \to E-TS-\mu N $$ is the thermodynamic grand potential.
mike stone
  • 58,971
  • 53
  • 158
