In the analysis of Harmonic Oscillator, it is claimed that $\langle\hat H\rangle$ cannot be zero, why is it so?
I mean $\hat H = \frac{ \hat p^2 }{2m } + \frac12 k \hat x^2$, and $$\left<x^2\right> = \int dx (x\psi(x))^\dagger (x\psi(x)) = 0$$ would imply that $x\psi(x) = 0 \quad \forall x.$ In particular, this is true when $x = 0$, so we have two options; either $\psi(x) = 0$ or $\psi(x) = \delta(x)$.
So, why can't $\psi(x) = \delta(x)$ in the case of Harmonic oscillator ?
Note: $\hat H = \frac{ \hat p^2 }{2m } + \frac12 k \hat x^2 $
Emilio Pisanty
  • 137,480
Our
  • 2,351
  • 19
  • 37
The state $\psi(x) = \delta(x)$ is a perfectly valid state for the harmonic oscillator to occupy. (With caveats, though: it is not normalizable, so it's not a physically-accessible state. Still, it's a perfectly reasonable thing for the mathematical formalism to handle.) As you note, it has a position uncertainty equal to zero, as well as a vanishing expectation value $⟨x^2⟩=0$.
However, it does not have a vanishing momentum uncertainty, and in fact if you expand it as a superposition of plane waves, $$ \delta(x) = \frac{1}{2\pi\hbar} \int_{-\infty}^\infty e^{ipx/\hbar}\mathrm dp = \frac{1}{\sqrt{2\pi\hbar}} \int_{-\infty}^\infty A(p) e^{ipx/\hbar}\mathrm dp, $$ you require an even weight $A(p) \equiv 1/\sqrt{2\pi\hbar}$ for all momenta, which means that the momentum-squared expectation value $$ ⟨p^2⟩ = \int_{-\infty}^\infty |A(p)|^2 p^2\mathrm dp = \frac{1}{2\pi\hbar}\int_{-\infty}^\infty p^2\mathrm dp = \infty $$ diverges to infinity. (This result is required by the uncertainty principle, but the derivation here does not rely on it - it's an independent proof of that fact. Still, you can see the consistency in that $\Delta x=0$ and $\Delta p \geq \hbar/2\Delta x$ can only be satisfied by having $\Delta p = \infty$.)
This then implies that the expectation value of the hamiltonian is also infinity: $$ ⟨H⟩ = \frac{1}{2m}⟨p^2⟩ + \frac12 k ⟨x^2⟩ = \infty. $$
As for this,
this is the zero-point energy of the oscillator, which has been explored multiple times on this site. If you want to ask why this is, you should ask separately, with a good showing of the previous questions here and what it is about them you do not understand.
Emilio Pisanty
  • 137,480
