-1
This question asks for the experimental result that is theoretically expected or is known already from experience, when one considers the following two scenarios for the micro-mechanical oscillator which can be put in an entangled quantum state with a qubit. See What exactly does Aaron D. O'Connell's experiment show? for a basic theoretical overview.
Experimental Scenario 1
When the qubit and oscillator are in a coherent superposition of direct product states, we make an attempt to view the oscillator, which has dimensions only in the micrometer range. Using a magnifying glass of high resolution, what do we see (or, if a similar operation has already been done, what was seen)?
I know that for viewing the micro mechanical-oscillator using an optical device, we are required to irradiate the oscillator with visible radiation. But, I am not sure if it's always strong enough to break the coherence.
Experimental Scenario 2
This question also assumes the oscillator to be in the same state as that of the previous question. Consider a small massive bob, which is set up such that any tiny changes in the gravitational field in its immediate surrounding could be detected. It is assumed to be placed close to the micro-mechanical oscillator. Let this bob also be kept in an ultra-cold environment as the oscillator, so that one need not worry about environmental decoherence.
In this context, we expect there to be a minuscule variation in the gravitational field experienced by the bob due to the varying distance between the bob and the center of mass of the oscillator. What does our measured value of gravitational field due to the oscillator look like as a function of time? Is it a smooth sine function?
Since these questions are experimental in nature, answers that contain information about similar ideas that have been implemented in experiments of the past are appreciated more than speculations.
Note: In the first question, I am using the word 'see', as it's always in principle possible to observe a micrometer sized object using an appropriate optical lens. To be more precise, let us say that we wish to see a tiny marking on the oscillator.
Emilio Pisanty
  • 137,480
By this, I imagine that you mean a state of the form $$ |\Psi⟩ = a \left| 1 \right\rangle_q \left| 0 \right\rangle_l + b\left| 0 \right\rangle_q \left| 1 \right\rangle_l $$ as in the answer to the question you've linked.
This state is an entangled state, which means that neither of the components of the system has a (pure, quantum) state of its own. That means, therefore, that if you want to do experiments that deal exclusively with either half of the system, you need to take the density matrix of the system, \begin{align} \rho & = |\Psi⟩⟨\Psi| \\ & = (a \left| 1 \right\rangle_q \left| 0 \right\rangle_l + b\left| 0 \right\rangle_q \left| 1 \right\rangle_l) (a^* \left< 1 \right|_q \left< 0 \right|_l + b^*\left< 0 \right|_q \left< 1 \right|_l) \end{align} and trace out the qubit, leaving you a state \begin{align} \rho_l & = \mathrm{Tr}_q \left(|\Psi⟩⟨\Psi|\right) \\ & = |a|^2 \, |0⟩_l⟨0|_l + |b|^2 \, |1⟩_l⟨1|_l \end{align} where there is no longer any coherence between the different states of the oscillator.
That's a bunch of technical language, the details of which you don't really need to understand, but here's the important part:
For any experiment that only deals with the oscillator and ignores the qubit, the state of the system is completely equivalent to a probabilistic mixture of the two states of the oscillator with respective probabilities $|a|^2$ and $|b|^2$.
Both of your proposed scenarios satisfy this hypothesis, which means that you will be completely unable to measure any quantum effects in either scenario.
Emilio Pisanty
  • 137,480
