We say pressure is isotropic. At any point in a fluid pressure acts equally in all directions, but pressure is perpendicular force per unit area so how can pressure be there in all directions as pressure will only exist if fluid molecules apply force perpendicular on other molecules.
Asked
Active
Viewed 369 times
Yes, pressure is the force perpendicular to a surface. Isotropic in that case simply means that the force will be the same regardless of the orientation of that surface.
Dale
- 117,350
Fluid molecules apply force perpendicular on other molecules.
This does happen.
But because many molecules surround a single molecule, the net force cancels out and so there is net effect of this force.
Harshit Joshi
- 1,221
