So I'm having a hard time understanding how the (QM) cross section fits into the general picture, of e.g. collider experiments. So we can calculate cross sections (for one reaction) exactly in QFT with Feynman diagrams (perturbation theory...). When we take the classical limit of these formulas, we find back for example the classical Thomson scattering of electrons on an electromagnetic potential.
To calculate the classical differential scattering (I'll take Thomson scattering as the general example here) we integrate over all possible impact parameters. This means we have a huge incoming UNIFORM flux + our possible targets and we calculate the statistical chance of what the distance is between one of the target particles and the incoming particles ( = impact parameter) so we can classically calculate the trajectory and the weighed possible outcomes, the differential cross section in other words. So this assumes we can't 'aim' our particles at one target particle.
With (relativistic) quantum mechanical calculations we can also get the same Thomson differential scattering, when we take the low velocity limit. So in principle we know we are doing physically relevant things.
Now my question is, when u shoot a (collimated) beam of particles on other target particles, you can calculate the differential cross section from quantum mechanics. These cross sections are calculated for one-on-one particle reactions, like electron scattering on a proton (QFT). But these calculations just 'suppose' a plane wave incoming directly on the center of the proton or the assumed target particles. Then we do something like, "event rate = flux x target particles x cross section". But where did we specify the impact parameter? Where did we say we aimed our incoming particles? In Quantum Mechanics it makes no difference what the 'distance' is between your incoming particle and target particle. The reaction just has 'a chance' of happening. Never ever in perturbation theory (QFT) have I used distances between particles, impact parameters or anything related to that. I know that in QM you can't see this problem classical anymore and we can't speak of exact positions and so on... But there still has to be a lower chance of having a reaction between the "top" of the incoming beam and the target particles at the "bottom". But still these experiments give us the right theoretical predicted results. I just don't see how we include these things into the quantum mechanical calculations of cross sections?
Imagine we just have the scattering of one particle on a target particle? How can we know what impact parameter we have (distance) as this will have an influence on the scattering, or in other words, the reaction chance of happening, or the cross section so to speak? Are we not making huge approximations as to assume we have a plane wave incoming which lands "exactly" in the middle of the (spherical) potential of the target particle? How does this translate to actual experiments? Why is there no 'statistical' treatment of this problem like with the classical variant and how is it that we can do this for 1 particle on 1 particle scattering without keeping in mind the influence of distance-like effects in QFT/QM.
  1. The differential scattering cross section (DSCS) of a process $$A~+~B ~\to~ C~+~\ldots$$ in CM & QM is [1,2,3] $$\frac{d\sigma}{d\Omega}=\frac{V}{T|\vec{v}_A-\vec{v}_B|}\frac{dP}{d\Omega},$$ where the differential probability is$^1$ $$\frac{dP}{d\Omega}=\frac{\#\{\text{scattered $C$-particles in time $T$ in direction }d\Omega\}}{\#\{\text{incident $A$-particles in }V\}\times \#\{\text{incident $B$-particles in }V\}}.$$ We assume opposite parallel/collimated incident beams with velocities $\vec{v}_A$ and $\vec{v}_B$ uniform as a function of transversal directions/impact parameter $b$. The longitudinal interaction region is assumed to be fairly localized. The transverse beam area is assumed much bigger than the particles.
  2. The elastic DSCM in CM & QM are expected to agree in the semiclassical limit $\hbar\to 0$ away from forward scattering (small scattering angle $\theta$), where QM (as opposed to CM) displays diffraction [4].
  3. Returning to OP's question, we may view the scattering as a probability distribution of an impact parameter $b$. Although we in practice would not know $b$ for 2 individual colliding particles, theoretically we could still in principle measure $b$ (and simultaneously loose information about dual observables, such as the transverse scattered momentum, cf. the HUP).
References:
  1. J.J. Sakurai, Modern Quantum Mechanics, 1994; eq. (7.1.35).
  2. M.D. Schwartz, QFT & the standard model, 2014; eqs. (5.2) + (5.6).
  3. M.E. Peskin & D.V. Schroeder, An Intro to QFT, 1995; eq. (4.59).
  4. M.V. Berry & K.E. Mount, Semiclassical approximations in wave mechanics, Rep. Prog. Phys 35 (1972) 315; Chapter 6.
$^1$ Refs. 1&2 assume there is just a single $B$-particle in $V$.
