Basically I want to know the validity of the statement, "All randomness originates from wave function collapse" or maybe "The only true random event is the collapse of wavefunctions"
This seemed to jive with me initially, but then I thought about the random fluctuations in underlying quantum fields, as well as the idea that the quantum fluctuations at the big bang combined with hyperinflation may have caused the uneven distribution of matter we see today. Those effects aren't due to wave function collapse, right?
Are there more sources of randomness? Is there a general statement we can make about randomness and where it physically originates from?
It is important to understand that fields don't fluctuate. This is explored in the question Are vacuum fluctuations really happening all the time? (spoiler: the answer is no).
The randomness you are talking about is due to measuring some quantity when the wavefunction is not an eigenstate of that quantity. For example suppose we are measuring energy. If our wavefunction is not an eigenstate of energy we can write it as a sum of energy eigenstates:
$$ \Psi = a_1 \psi_1 + a_2 \psi_2 + a_3 \psi_3 + ~ ... $$
where the $\psi_i$ are the energy eigenfunctions. Then measuring the energy randomly collapses the wavefunction to one of these eigenstates $\psi_i$ with probability $\left| a_i \right|^2$. This is the random element in QM, and it applies to quantum fields in exactly the same way.
John Rennie
  • 367,598
This problem is common to physics where the observations are always sets of "points".
When the number of points is big, one has a clear "image"; otherwise several or one point are not representative.
In Classical Mechanics one makes an average over the set of points at a "time" (=time interval) and finds a "deterministic" behavior of such "mean values" (coordinates of the Moon, for example). When the number of points is small (the light intensity is small), the observation results are vague or useless. One always has to have a good statistics to say something certain about observations.
Note also , the observed body must change (radiate or absorb) in order to be observed, so we attribute the image of an "objective" entity to something that is not objective (intact), but changing! The primary thing is a set of points due to exchange of energy; the produced image is some sort of avatar rather than the true entity, so it depends on the way we process (treat) the obtained data.
-1
Even without collapse, a wavefunction provides an intrinsically random description. Knowing it is just providing the building block to know the probability of a measurement. I.e., the result of a measurement is a random variable. What else?
As a side remark, I would add that there is no intrinsic necessity for a quantum field to fluctuate. That is a misconception. Would you say that a wavefunction would fluctuate?
