10
I have read through this question Rotation of Particle and this paper What is Spin. I have a basic understanding of the math treatment of spin in relation to electrons, but my question is:
Can we assign a physical (classical / correspondence principle) interpretation to the double rotation (720 degrees) required to describe electrons?
It is possibly simply a means of classification as a fermion, as opposed to other particles. or a link in the chain connecting left handed particles to the weak force.
I am more than wary of assigning too much physical intuition (or any, in some cases), to any mathematical model of elementary particles. So I appreciate that "spin" here is not the same as a spinning football, in any way.
I am currently reading on the solutions to the Dirac equation, and I realise that the Pauli matrices are essential to them, but what I am looking for is an answer to:
Is there any classical effect that we can point to, and say, "Without treating the electron as a spinor, i.e. needing a double rotation, (mathematically speaking), we could not explain this or that particular phenomenon"?
5 Answers5
12
For an isolated electron, an overall 360 degree rotation gives a state that is physically identical to the original. It changes the sign of the quantum state-vector, $|\psi\rangle\rightarrow -|\psi\rangle$, but the overall complex coefficient of a quantum state-vector has no physical significance: the vector $z|\psi\rangle$ represents the same physical state for all non-zero complex numbers $z$. But, as mentioned in Andrew Steane's answer, things can become more interesting when more complex situations are considered. I'll say more about this below.
It is possibly simply a means of classification as a fermion, as opposed to other particles...
The spin-statistics theorem from relativistic QFT says that there is a connection between fermions and half-integer spin (and between bosons and integer spin). In nonrelativistic quantum mechanics, that theorem does not hold; we only enforce the connection manually because we know that nonrelativistic QM is supposed to be an approximation to relativistic QFT. So maybe the double-rotation property could be regarded as a means of classifying particles as fermions in relativistic QFT, but not in nonrelativistic quantum mechanics — again as mentioned in Andrew Steane's answer.
That depends on what is meant by "classical effect". There are innumerable effects with macroscopic consequences that can't be explained without treating electrons as spin-1/2 particles, such as ferromagnetism (as emphasized in my2cts's answer) and the specific ways that atoms and molecules interact with light, like the difference between fluorescence and phosphorescence. However, if the focus of the question is on the double rotation property of spin-1/2 particles, then one of the most direct manifestations is in the neutron interference experiments reviewed in this paper:
These are basically two-slit experiments with a macroscopic distance between the two paths in the interferometer. Diffraction in a crystal was used as a substitute for "slits." Magnets were arranged in a way that would cause precession of any neutron that passes through one of the paths, and the effect on the resulting two-slit interference pattern displays the effect of the sign-change under 360-degree rotations that characterizes spin-1/2 particles.
Despite the macroscopic distance between the slits, calling this a classical effect might be a stretch, because it relies on quantum interference between the two paths through the interferometer. If $|A\rangle$ and $|B\rangle$ represent the states of a neutron passing through path $A$ or path $B$ in the interferometer, then the experiment described above amounts to preparing the neutron in a state $|A\rangle+|B\rangle$, then applying a 360-degree rotation in the $B$-path to get the state $|A\rangle-|B\rangle$. Although an overall sign-change has no observable consequences, this relative sign-change does have physical consequences — which are observed in the resulting interference pattern in these experiments.
Whether or not this macroscopic effect deserves to be called classical is left to the discretion of the OP.
Chiral Anomaly
  • 55,710
  • 99
  • 166
This is a good question. I am not going to answer it fully, but I will offer some relevant pointers.
Spin is quantum mechanical in the sense that everything is, including orbital angular momentum, but it's not true to say that there is no classical (i.e. not quantum) mathematical apparatus for spin. You can have a classical particle possessing rest mass and spin, described by a spinor, and you can have a classical spinor field. In this sense, spin is no more quantum mechanical than any other physical property. It's just that historically physicists became aware of it at the same time as they were discovering quantum mechanics, so they incorporated it into quantum mechanics from the start. Having done that, we can go back and incorporate it into classical mechanics if we want.
Having said that, I think one might be able to make a case that you can't have a relativistic quantum theory without spin, whereas you can have a relativistic classical theory without spin.
The double-rotation property can be related to something called 'angle doubling' in the correspondence between two groups called SU(2) and SO(3). I wrote an introduction (at senior undergraduate level) at https://arxiv.org/abs/1312.3824. (There may be other equally good or better introductions of course). For a classical observation that directly reveals the double-rotation property, I have not got a concrete suggestion, but I strongly suspect you would need a situation where one particle (say an electron) is interacting with another, and you rotate the first particle, for example using a magnetic field.
Andrew Steane
  • 65,285
We cannot explain ferromagnetism without spin, nor any other form of permanent magnetism. Of course, you could argue that any phenomenon that requires spin is quantum mechanical.
my2cts
  • 27,443
Possibly.
Here is a metaphor, something else which might work similarly.
When you have circularly polarized light, the polarization changes in a cycle. Knowing the lightspeed and the frequency, and the polarization at one point and one time, we can predict the polarization angle at that point for any other time.
But we say that the frequency is half the rate that the polarization changes! When the polarization changes from horizontal to vertical and back to horizontal, the amplitude has not gotten back to its original value but is the negative of it! Woo! Weird! Well no, it isn’t. There’s nothing weird or unusual about that, that’s just how it works. It only looks weird if we think that the frequency is double the actual frequency, because we can’t tell the difference between one polarization state and the polarization state 180 degrees from it. It doesn’t take something special about spinors for that. All it takes is to pretend that the rotation speed is double the actual rotation speed.
Maybe we are pretending that the electrons are rotating twice as fast as they are, because of something that acts like polarization. It might all make more sense when you have single rotation and some things but not others are restored to their original state after half a rotation.
J Thomas
  • 3,146
It's a wrong question to ask "why double rotation $720°$ is necessary to describe electrons".
Actually, a $360°$ single rotation is necessary to bring a spin 1/2 particle back to its initial state. The proper question is "why a $360°$ single rotation of a spin 1/2 particle is translated to $720°$ double rotation of a vector". As you can see, the "double rotation" is on a vector, not on a spinor!
See more explanations here and here.
Additionally, as mentioned in @Andrew Steane's answer, "you can have a classical spinor field. In this sense, spin is no more quantum mechanical than any other physical property". For more details about the classical spinor, see here.
MadMax
  • 5,451
  • 13
  • 42
