Is earth considered as inertial frame? I was confused because we learned about Coriolis effect. We know that earth spins therefore Coriolis effect should take place . But does it have minimal effect for motion of balls etc when they move with respect to the ground?
The surface of the Earth is not, rigorously speaking, an inertial frame of reference. Objects at rest relative to Earth's surface are actually subject to a series of inertial effects, like the ficticious forces (Coriolis, centrifugal etc.) because of Earth's rotation, precession and other kinds of acceleration.
When solving physics problems, however, we usually take the Earth frame as being inertial. This is because the inertial effects are minuscule for most of our day-to-day experiences and experiments. For example, objects in the Equator are the ones subject to the strongest centrifugal force and it is only about $3 \times10^{-3}$ or $0.3\%$ of their weight.
So for the most part, if an experiment is short enough and happens in a small enough region, the surface of Earth can indeed be approximated to an inertial frame of reference since the effects on the experiment's results are very, very tiny.
This of course has exceptions, as cited in njspeer's answer.
If however by "Earth" you mean the reference frame in Earth's center, it is an inertial frame according to General Relativity (GR), since observers in free fall are inertial in GR. The Earth actually does have some proper acceleration due to external forces such as radiation pressure, but these are also minuscule effects.
- 1,273
Because the earth is rotating, it is never strictly an inertial reference frame. However, because the effects are small in many situations, it can often be approximated as one. When to use Coriolis forces will have to be determined on a case-by-case basis. E.g. ballistic problems that cover large distances will most certainly require Coriolis-force corrections, and pendulums that swings for a long time would also require Coriolis-force corrections. For a block sliding down an inclined plane, or a spring on a mass, or a vibrating string, you should not need to take it into consideration.
- 622
Mach would say that non-inertial effects are due to the relative motion between the earth and the rest of the universe.
See:
• Assis, André K. T. Relational Mechanics and Implementation of Mach’s Principle with Weber’s Gravitational Force. Montréal: Apeiron, 2014.
- 2,191
I know it's being a little pedantic, but I would say "earth" is a thing, not a reference frame. You could define an inertial reference frame that contains the earth.
But suppose you mean a reference frame defined with reference to the earth: Z is perpendicular to the ground where you are standing, X and Y are parallel to the ground and perpendicular to each other.
If you stand at rest in this reference frame, you may notice you feel acceleration (gravity). It is therefore not an inertial reference frame.
- 495
The experiment utilising Newton's laws of motion is carried out in an inertial frame, which is defined as the observer's or, more accurately, the ground frame, which is more or less stationary with regard to the earth.
You can interpret it in this manner, if a stone is on the ground and a camera is pointed in the direction of the stone in the centre of the earth...In a hypothetical sense...You will notice that The Rock does not move with respect to camera frame.
Similarly, when both we, the observer, and the object that is in the experiment are in non-relative motion with respect to the earth.
Also, your condition of earth's Coriolis effect is true, in that it makes no major significant change in the outcome of the experiment.
- 62
