What is meant by the statement that information cannot travel faster than light?
If I write down something on a paper, isn't there according to QM a non-zero probability that an identical paper can spontaneously fluctuate into existence a lightyear away?
Can't a person successfully guess every character that I write, every time?
Is this why QM and GR are incompatible?
If not, which principle or axiom of QM must be modified to be compatible with GR?
Is there any difference between ordinary particle travel and particles fluctuating in and out of existence along what looks like the world-line of a particle?
Other than different probabilities?
Can a Ferrari spontaneously fluctuate into existence according to QM?
What happens then to Energy conservation?
Asked
Active
Viewed 273 times
1) google it (this forum requires you to first do some research of your own on your questions)
2) no, that would violate Conservation of Mass (QM says virtual particles pop in and out of existence, which are not real particles)
3) yes, so what?
4) no
5) this should be your main question, I can elaborate on it later.
6) yes, because the "particles" fluctuating in and out of existence are not real (see (2))
7) see (2)
8) see (2)
9) it is preserved (for actual particles)
Chris Gerig
- 2,798
