With the recent redefinition of the kilogram, what is the mass of $N_A$ (Avogadro's constant) of carbon-12 atoms? $N_A$ was defined as exactly 6.02214076×$10^{23}$ atoms. Then how close would the mass of $N_A$ atoms of carbon-12 be to 12 grams?
Is it still true that the mole is the amount of substance of a system which contains as many elementary entities as there are atoms in 12 gram of carbon-12? Is a mole exactly $N_A$?
Emilio Pisanty
  • 137,480
Sheldon
  • 103
The status of the mass of a mole of $^{12}\rm C$ in the revised SI is basically identical to that of the magnetic vacuum permeability $\mu_0$, which is explored in this and this question. The SI revision does not consist of a re-definition of the kilogram in isolation $-$ instead, the full set of the seven base units get redefined, including in particular the mole, which is no longer defined in terms of a fixed value of the molar mass of carbon-12 and which is instead tied to a fixed value of the Avogadro constant. For the full details, see the over-arching Q&A What are the proposed realizations in the New SI for the kilogram, ampere, kelvin and mole? (as well as this table in the Wikipedia page to see how all the relevant units and constants change status), but the short answer to your question
Then how close would the mass of $N_A$ atoms of Carbon-12 be to 12 grams?
is that it will be close, but not exactly equal, and it will be an experimentally-determined quantity with a finite uncertainty in the future.
This is spelled out explicitly in the Resolution that implements the revision (which will presumably be named as Resolution 1 of the CGPM 2018), and particularly in its appendices, which contain an explicit definition of the mole,
The mole, symbol mol, is the SI unit of amount of substance. One mole contains exactly $6.022 140 76 \times 10^{23}$ elementary entities. This number is the fixed numerical value of the Avogadro constant, $N_A$, when expressed in the unit $\rm mol^{–1}$ and is called the Avogadro number.
The amount of substance, symbol $n$, of a system is a measure of the number of specified elementary entities. An elementary entity may be an atom, a molecule, an ion, an electron, any other particle or specified group of particles.
as well as an explicit comment on the status of the molar mass of carbon-12,
the molar mass of carbon 12, $M(^{12}\mathrm C)$, is equal to $0.012 \:\rm kg \: mol^{–1}$ within a relative standard uncertainty equal to that of the recommended value of $N_Ah$ at the time this Resolution was adopted, namely $4.5 \times 10^{–10}$, and that in the future its value will be determined experimentally.
The appearance of the Planck constant $h$ on the relative uncertainty of $M(^{12}\mathrm C)$ after the change is directly tied to the fact that the relative uncertainty in the mass of the International Prototype Kilogram immediately after the change is exactly equal to the current relative uncertainty in $h$ (because of the way the switch is carried out, and because the second and the meter don't have significant changes).
Emilio Pisanty
  • 137,480
