On Shankar page 217 when going from the operator representation to the differential representation he starts with
$$a|0\rangle = 0$$
And says that with a projection on the X basis we get
$$|0\rangle \rightarrow \langle x|0\rangle = \psi_0(x)$$
And with $$a=\frac{1}{\sqrt{2}}\left(y+\frac{d}{dy}\right)$$
It’s stated that in the X basis of our first equation ($a|0\rangle=0$) we get $$\left(y+\frac{d}{dy}\right)\psi_0(y)=0$$
I’m wondering how this makes any sense. From the way it’s set up it sounds like he’s doing $$\langle x|a|0\rangle$$ which would be annihilated as per the first equation. But the result he gets is the same as if he did $$a \langle x|0\rangle$$ but you can’t just pull the $a$ out because it has a $p$ in its definition. What is going on here?
First, we need to lay out some preliminaries in the language of Shankar's book. If you want, you can skip to the bottom where I apply the following to your question.
When you express a state $|\psi\rangle$ in the position basis, what you're doing is applying the identity operator $\mathbb{1} = \int dx \ |x\rangle\langle x|$ and defining $\langle x | \psi \rangle \equiv \psi(x)$ to be the position-space wave function corresponding to the state $|\psi\rangle$.
$$ |\psi \rangle = \int dx \ |x \rangle\langle x | \psi \rangle \equiv \underbrace{\int dx \ |x \rangle \underbrace{\psi(x)}_{\text{Wavefunction}}}_{\text{Entire state}}$$
When you express an operator $\hat O$ in the position basis, what you're doing is applying the identity operator $\mathbb{1} = \int dx |x \rangle\langle x |$ from the right and $\mathbb{1} = \int dx' |x' \rangle\langle x' |$ from the left and defining $ \langle x'|\hat O|x\rangle \equiv O_{xx'}$ to be the position-space representation of the operator $\hat O$.
$$\hat O = \iint dx \ dx'\ |x'\rangle\langle x'|\hat O |x \rangle \langle x | \equiv \iint dx\ dx' \ |x'\rangle O_{xx'} \langle x|$$
( Note that $\hat O$ eats states and spits out other states, while $O_{xx'}$ eats (wave)functions and spits out other functions.)
From here, we can write, we can write
$$\hat O |\psi\rangle = \left(\iint dx\ dx' |x'\rangle O_{xx'} \langle x| \right)\left(\int dy \ |y\rangle \psi(y)\right)$$ $$ = \iiint dx \ dx' \ dy \ |x'\rangle O_{xx'} \langle x|y\rangle \psi(y)$$
We can use the fact that $\langle y|x\rangle = \delta(x-y)$ to eliminate the integration over $y$ and yield
$$\hat O | \psi\rangle = \iint dx \ dx' |x'\rangle O_{xx'} \psi(x)$$
This is the most general possible expression for action of the operator $\hat O$ on the state $|\psi\rangle$ as expressed in the position basis.
In your question, you refer to $\hat a \equiv \frac{\hat X + i\hat P}{\sqrt{2}}$ (where we've set all the constants equal to 1 for simplicity - you can put them back in as an exercise). In the position basis, we have that $$X_{xx'} \equiv \langle x' | \hat X | x\rangle = x \delta(x-x')$$ and $$P_{xx'} \equiv \langle x' | \hat P | x\rangle = -i\delta'(x-x') = -i \delta(x-x') \frac{d}{dx'}$$ and so
$$a_{xx'}\equiv \langle x' | \hat a | x\rangle = \delta(x-x') \left(\frac{x + \frac{d}{dx'}}{\sqrt{2}}\right)$$
The wavefunction of your state is unknown at the moment, but you can call it $\psi_0(x)$. Plugging the operator $a_{xx'}$ into the integral we found earlier yields
$$\hat a|0\rangle = \iint dx \ dx' |x'\rangle \delta(x-x') \left(\frac{x + \frac{d}{dx'}}{\sqrt{2}}\right) \psi_0(x) = \int dx |x\rangle \frac{1}{\sqrt{2}} \left( x + \frac{d}{dx}\right)\psi_0(x) $$
which means that $\hat a|0\rangle$ yields a new state whose wavefunction is given by
$$\phi(x) = \frac{1}{\sqrt{2}}\left(x + \frac{d}{dx}\right) \psi_0(x) = 0$$
where the last equality arises because we know that $\hat a$ annihilates the state $|0\rangle$.
Albatross
  • 72,909
Your confusion comes from the fact that the annihilation operator $\hat a$ is in fact not equal to $\frac 1{\sqrt{2}}(x+\frac d{dx})$. $\hat a$ is an operator acting on an abstract Hilbert space in which the state vector $|\psi \rangle \in \mathcal H$ exists. The differential operator $\frac 1{\sqrt{2}}(x+\frac d{dx})$ is an operator acting on the space of functions, not the abstract vectors of $\mathcal H$. It is the action of $a$ on any vector $|\psi \rangle$ in the position representation ($x$ eigenbasis) that resembles the differential operation $\frac 1{\sqrt{2}}(x+\frac d{dx})$.
To see this more clearly, note that the state vector $|\psi \rangle$ is not even a function of $x$, whereas the wavefunction $\psi(x) \equiv \langle x | \psi \rangle$ is.
More explicitly: $$\hat{a}|\psi \rangle \neq \frac 1{\sqrt{2}}(x+\frac d{dx}) |\psi \rangle \qquad \text{doesn't even make sense since $|\psi \rangle$ is not a function of $x$}$$
What does make sense is decomposing $|\psi \rangle$ in the $x$ eigenbasis as $|\psi \rangle \equiv \int_{-\infty}^\infty dx |x \rangle \langle x|\psi \rangle $ or equivalently $|\psi \rangle =\int_{-\infty}^\infty dx |x \rangle \psi(x)$, and then saying that: $$\hat{a}|\psi \rangle = \int_{-\infty}^\infty dx \frac 1{\sqrt{2}}(x \psi(x)+\frac d{dx}\psi(x))|x \rangle \qquad \text{makes sense, both sides are vectors in $\mathcal H$}$$ Or equivalently, by multiplying $\langle x|$ from the left: $$\langle x| \hat a|\psi \rangle = \frac 1{\sqrt{2}}(x \psi(x)+\frac d{dx}\psi(x))$$ which is what was used in the book as you've mentioned yourself. Also note that $\hat a \langle x | 0 \rangle$ doesn't make sense, because $\langle x | 0 \rangle \in \mathbb C$ is not a member of $\mathcal H$, meaning that $\hat a: \mathcal H \rightarrow \mathcal H$ can't even act on it.
Check out this similar question and its answers for more details.
