In a comment, Elio Fabri says:
A well-known case is the famous paradox of the two capacitors, one charged, the other uncharged. If you connect them, charge is shared, and energy appears not being conserved. But if the connecting wire has a non-null resistance $R$, you can see that the lacking energy is dissipated as Joule heat in $R$. The paradox is that the energy dissipated does not depend on $R$, so that the limit $R\rightarrow$ 0 would still give the same value.
I haven't thought about it very deeply, and I'm sure others have analyzed this carefully, but it seems to me that for small values of resistance, this circuit would behave like an $LRC$ circuit and exhibit oscillations, and in the limit $R\rightarrow0$, radiation would become a more efficient dissipative mechanism than resistive heating. Is this a correct analysis?
in the limit R→0, radiation would become a more efficient dissipative mechanism than resistive heating. Is this a correct analysis?
That would depend on the physical construction of the circuit, how big a loop the wires formed, etc.
The well-known result essentially assumes you build the circuit small enough that radiation is not significant. This is a very common assumption in circuit theory, called the lumped circuit approximation.
In this case, we can still find a mechanism to explain the difference in capacitively stored energy after connecting the two capacitors, so we don't need to go look for radiation as an explanation.
The Photon
  • 29,651
This recently updated problem and solution, A Capacitor Paradox, by Kirk T. McDonald is well worth a read. I've referenced it in a few answers (for example, this one) and comments related to questions regarding the two capacitor missing energy 'paradox'. Quoting McDonald:
Indeed, for low Ohmic resistance, the current in the circuit would perform a damped oscillation with nominal angular frequency $\omega_0 \approx \sqrt{2/LC}$, and the associated electric and magnetic dipole radiation would have power well described by $P_{rm}(t)=I^2(t)R_{rad}$ where $R_{rad}$ is a constant with dimensions of electrical resistance.
So, your intuition is in agreement with McDonald's analysis.
