I've been taught that, to find a given observable, one most apply the Hermitian operator pertaining to that observable. However, the function the operator the observable is being applied to must be an eigenfunction of that operator. An example of such would be something like:
$$\psi (x,t) = A e^{-i(kx-bt)}$$
This would be an eigenfunction of the momentum operator With eigenvalue $\hbar k$. This literally is equivalent to $p$, so when I'm told that an eigenfunction of an operator is a function where $\hat p \psi = p \ \psi$, then I whole-heartedly agree. However, if
$$\psi (x,t) = A e^{-i(\sqrt{\tau}\ x-bt)}$$
Then, it is still an eigenfunction of the momentum operator with eigenvalue $\hbar \sqrt{\tau}$. This is still okay with me, as the momentum must just be that value.
What confuses me, however, is that none of the solutions to Schrodinger's equation that I've learned so far even are eigenfunctions of momentum.
For instance, the solution to the infinite square well is sinusoidal, and thus has a complex eigenvalue which makes the momentum operator not produce a real observable in this case. In addition, I'm doubtful that Hermite's polynomials, solutions to a quantum harmonic oscillator, will be eigenfunctions either. Gaussian wavefunctions aren't eigenfunctions of momentum either - although I know it doesn't have a definite momentum, clearly. This seems weird to me. Why am I being taught these things if it only works in such rare cases? Can the momentum of an infinite square well eigenstate not be measured? This does not seem obvious to me. I'm maybe close to getting it. Definite momentum is only achievable with plane waves, which is why my first example worked - but if operators only seem to work on plane waves why do we use them?
sangstar
  • 3,280
This is where the mistake lies. Making a measurement of some observable is not performed mathematically by calculating $\hat P\psi(x)$ In fact, you can't do anything "to find a given observable" in general. All you can look at is expectation values: $$\langle\hat P\rangle=\langle\psi|\hat P|\psi\rangle$$ In other words, you can't determine the result of a measurement of a quantum system by operating on the state vector with the corresponding operator. This is not how QM works.
You are additionally making the assumption that your state has to be an eigenstate of an operator in order to make a measurement of the corresponding observable. The general way to approach determining the probability of measuring some observable is to expand it in the eigenbasis of the corresponding operator. Then the "coefficients" for each basis vector (eigenvector) relates to the probability of measuring the corresponding eigenvalue.$^*$ For momentum $|\psi\rangle=\int|p\rangle\langle p|\psi\rangle\ dp=\int\psi(p)|p\rangle\ dp$, and we can determine $\psi(p)$ if we already know $\psi(x)=\langle x|\psi\rangle$: $$\psi(p)=\langle p|\psi\rangle=\int_{-\infty}^{\infty}\langle p|x\rangle\langle x|\psi\rangle\ dx=\frac {1}{\sqrt{2\pi\hbar}}\int_{-\infty}^{\infty}e^{-ipx/\hbar}\psi(x) dx$$
Then $|\psi(p)|^2$ can tell us the probability of measuring a momentum value between $p$ and $p+dp$. For eigenstates of momentum with eigenvalue $p'$, $\psi(p)=\delta(p-p')$, which means that we can only measure $p'$ for momentum.$^{**}$
We use the operators because the eigenvalues of the operators correspond to the values we can measure of these observables. The operators tell us what we can measure, and they give us nice ways to write our state vectors $|\psi\rangle$ so that the probability of measuring these observables are easy to calculate (as shown above).
$^*$ If you want something we use to operate to determine the "result" of a measurement, what you want instead is the sum of projection operators. For a general observable with corresponding operator $A$, eigenvectors $|a\rangle$ and eigenvalues $a$, we have $$|\psi\rangle=\sum_a|a\rangle\langle a|\psi\rangle=\sum_a\psi(a)|a\rangle$$ $$|\psi\rangle=\int|a\rangle\langle a|\psi\rangle\ da=\int\psi(a)|a\rangle\ da$$ for discrete and continuous spectra respectively. $\psi(a)$ gives you all you need to know about the probability of measuring a value of $a$ for our observable.
$^{**}$States like these are actually non-physical, but I don't think I need to go into the discussion of this for your question. There are other answers on this site that can go into more detail if you want to learn more.
BioPhysicist
  • 59,060
