Consider the Klein-Gordon equation: \begin{equation} \frac{\partial^2 \psi}{\partial t^2} = c^2 \Delta \psi - \frac{m^2 c^4}{\hbar^2} \psi, \end{equation} and define for each one of its solutions $\psi$ the quantity:
\begin{equation} P(\mathbf{x},t)= \hbar^2 \frac{\partial \psi}{ \partial t} \frac{\partial \psi^{*}}{ \partial t} + \hbar^2 c^2 \nabla \psi \cdot \nabla \psi^{*} + m^2 c^4 \psi \psi^{*}, \end{equation} Let us adopt the convention in which the generic point of the Minkowski space-time is $(x,y,z,ct)$. In Section (4.6) of his wonderful treatise Quantum Theory Bohm states that under a Lorentz transformation
(i) $P(\mathbf{x},t)$ transforms as the (4,4)-coordinate a rank two tensor,
(ii) $\int P(\mathbf{x},t) d\mathbf{x}$ transforms as the fourth component of a four-vector.
Could someone give me a proof of these two statements, please?
NOTE (1). All that I know about the Klein-Gordon equation is that $\psi$ is invariant under Lorentz transformations, that is if $\psi(\mathbf{x},t)$ is a solution of the Klein-Gordon equation, then the new function $\phi(\mathbf{x'},t')$ obtained by replacing the equations of a Lorentz boost $(\mathbf{x},ct) \rightarrow (\mathbf{x'},ct')$ in $\psi$ is again a solution of the Klein-Gordon equation.
NOTE (2). Bohm justifies assertion (i) by considering the particular solution $\psi= \exp i \left( \frac{Et-\mathbf{p} \cdot \mathbf{x} } {\hbar} \right)$, for which we get \begin{equation} P=E^2+p^2c^2+m^2c^4=2E^2, \end{equation} so that $P$ transforms actually as the square of an energy.
