The standard way to encode vectors on the Bloch sphere sets the first component as a positive real number, and this convention is influenced by that.
But that's about it: it is a convention, and you're welcome to change it if there's a specific reason why that would suit your purposes better.
However, if there isn't a well-defined reason why it's better for you in some measure, then I would advice against trying to buck this convention: the only thing that it's going to achieve is that a good fraction of your readers is going to waste time wondering why the phase convention on your eigenbases has been chosen in a non-standard way, and you want your readers' attention to be focused on what you want to say instead of on your notation. The positive-first-component is just a part of the shared language that makes it easier to communicate clearly about the content; there's no good reason to make one choice over others (unlike in other domains) but having a common choice that breaks that degeneracy takes that uncertainty out and leaves more room for the physics.
