The question arises when I'm reading over the section "3.3.1 Minkowski Space" in page 16-17 in the following link: https://www-thphys.physics.ox.ac.uk/people/JohnCardy/qft/qftcomplete.pdf
It is discussing the technique of using Wick Rotation to calculate the generating function in Minkowski space.
It mentioned that simply inserting $τ=it$ into the results of the generating function in Euclidean space (i.e. imaginary time) provides the generating function in Minkowski space.
However, on top of page 17, it mentioned that I also have to let $p_0 \to ip_0$ as well. Why do I have to do this as well? How is that related to defining $τ=it$ and making a Wick Rotation?
A Wick-rotation in spacetime $x^{\mu}$ implies via Fourier transformation a Wick rotation in Energy-momentum space $p_{\mu}$. Perhaps the easiest way to convince oneself that this must be so is to consider the Fourier-integral representation $$\delta^4(x)~=~\int_{\mathbb{R}^4} \frac{d^4p}{(2\pi\hbar)^4}~\exp\left(\frac{ip\cdot x}{\hbar} \right)\tag{A}$$ of the Dirac delta distribution. It cannot be analytically continued to the ambient complexified spacetime. The real integration region can at most be deformed, i.e. the $x^0$ and $p_0$ Wick-rotations must be balanced. See also e.g. this and this related Phys.SE posts.
Cardy discusses how to pass from euclidean space to Minkowski space.
The Wick rotation can be thought of as a coordinate transformation $x' \rightarrow x$, where the $x' \equiv (\tau, \vec{x}')$ are the euclidean ones and the $x \equiv (t,\vec{x})$ are the ones for Minkowski space (see below for a caveat). As stated in the question $\tau = \mathrm{i} t$.
A covector transforms according to
$$ \omega_\mu = \frac{ \partial x'^\nu }{ \partial x^\mu } \omega'_\nu. $$ Using this transformation law for the vector $p_\mu$ we get for $p_0$ $$ p_0 = \frac{ \partial x'^\mu }{ \partial x^0 } p'_\mu = \frac{ \partial x'^0 }{ \partial x^0 } p'_0 = \frac{ \partial \tau }{ \partial t } p'_0 = \mathrm{i} p'_0 . $$
Now for the caveat. Viewing the Wick transformation as a coordinate transormation gives the following metric
$$ g_{\mu\nu} = \frac{ \partial x'^\alpha }{ \partial x^\mu } \frac{ \partial x'^\beta }{ \partial x^\nu } g'_{\alpha\beta} = \mathrm{diag}(-1,1,1,1)_{\mu\nu} $$ which in Cardy's conventions is the negative of the Minkowski metric.
yalda
