I have read this question:
Elementary particle (electron) and non-elementary (proton) spagettification
and the comments where it says:
But no real elementary particle can be confined in a region smaller than its compton wavelength.
An these questions:
What is the physical significance of Compton wavelength?
Confining a particle into a region shorter than its Compton wavelength
https://en.wikipedia.org/wiki/Compton_wavelength
Where Veritas' answer says:
Yes, this will happen. But you cannot confine particle in the vacuum. To confine a particle, you must have some potential. The energy to produce pairs must come exactly from this binding potential. For example, you can confine electron using a very strong electric field. To confine an electron in a region smaller than its Compton wavelength you need a field with enough energy to create electron position pairs. Particle in a vacuum will never be confined.
So which one is right?
Question:
- Can elementary particles be confined into a smaller region then their Compton wavelength?
