The surface gravity of a Schwarzschild black hole is said to be inversely proportional to the mass of the black hole. But if the event horizon represents the "point of no return" even for light, then I would have thought that the surface gravity must have a fixed relationship to the speed of light, and hence should be the same for all black holes regardless of mass. Why am I wrong?
As with so many things in GR the answer depends on exactly what you mean and which observer you are considering.
There is a property called the surface gravity, $\kappa$, that is defined in a rather technical way but is kind of the gravitational acceleration at the event horizon in the reference frame of a distant observer. This is given (in geometrical units) by:
$$ \kappa = \frac{1}{4M} = \frac{1}{2r_s} $$
so this is indeed inversely proportional to the black hole mass/radius. This surface gravity is not something that can be directly observed i.e. it is not something any observer could measure with their accelerometer. However it is an important property of a black hole. For example the temperature of the Hawking radiation is proportional to the surface gravity, as discussed in my answer to Why do larger black holes emit less Hawking Radiation than smaller black holes?.
However this is not the gravity someone hovering near the event horizon feels. If you hover at a distance $r$ from the centre of the black hole the gravity you feel is:
$$ a=\frac{GM}{r^2}\frac{1}{\sqrt{1-\frac{r_s}{r}}} $$
and as you approach the event horizon, i.e. as $r \to r_s$, this gravitational acceleration goes to infinity. This is true for any size of black hole.
The reason the surface gravity is finite while the acceleration felt by a hovering observer goes to infinity is because the hovering observer's time is dilated. If you are hovering close to the event horizon while I am far from the black hole your clock will be running more slowly than mine. Acceleration has units of metres per second squared, and it's because the two of us disagree about the length of one second that we disagree abut the gravitational acceleration.
- 5,296
- 367,598
