Remember that from Planck's postulate, $E=hf$ stands for wave-particle matters, and that if 2 waves with same energy cancel out as you assume, the quantum mechanics interpretation as both of them free particles is a process of creation/annihilation of pairs after a collision, with a remnant of energy product of the kinetic energy before and after the collision (light photons and heat).
If you want to use $E=hf$ in a classical treatment, for 1D, then you can work out:
$$\Psi_1(x)=A\exp \left[i\left(kx-\omega t\right)\right]=A\exp \left[i\,2\pi\left(\frac{x}{\lambda}-\frac{Et}{h}\right)\right]$$
$$\Psi_2(x)=A\exp \left[i\left(kx-\omega t\pm\pi\right)\right]=A\exp(\pm i\pi) A\exp \left[i\left(kx-\omega t\right)\right]=-A\exp \left[i\left(kx-\omega t\right)\right]=-A\exp \left[i\,2\pi\left(\frac{x}{\lambda}-\frac{Et}{h}\right)\right]$$
$$\therefore \Psi_1+\Psi_2=0$$
Computing the total (kinetic) energy of both waves:
$$E=E_1+E_2=kA^2,$$
which does not say too much. But using a bit of what we learn from Modern Physics:
$$E_1+E_2=2hf=2\dfrac{h}{\lambda}v=2pv.$$
Notice that for $v=c$, one has the total energy of a photon using quantum mechanics (Planck-De Broglie's postulate $p=h/\lambda$) from a classical picture. Thus, for electromagnetic waves, you get that the total energy of the system would be that of 2 photons, which is emitted (absorbed) during the process.
