In special relativity velocity is relative and there is no absolute rest frame . However the cosmic microwave background radiation does have a rest frame. Earth is moving with 328 km/s with respect to this frame, on average, and the local group with 627 km/s. It is plausible that this remnant of the big bang represents the rest frame of all matter in the universe. The question is therefore: does the CMB falsify the tenet of SRT that velocity is relative ? Or should we see all matter in the universe as just another object moving in space ?
This questions turns on a focus on words over the physics they are suppose to describe.
Special relativity says that physics (including Maxwell's equations) is the same in every inertial frame. The word "absolute" is a distraction from the important principle about physics.
Sure the CMB has a local rest frame. So what? Everything has a rest frame (even accelerating objects have a momentarily co-moving frame).
Those things are identifiable frames. They are not absolute in the sense that physics is different for those frame than for any other.
All particles in an ensemble with their $(E,p_x,p_y,p_z)$ vectors can be transformed to an inertial frame where the summed momentum is zero, a rest frame. For zero mass particles at least two non collinear ones are needed for a definition consistent with special relativity ( a zero mass particle has no rest frame, ).
So , yes, one studies the CMB in its rest mass system, against which the motion of the earth has been detected as a distortion to the hypothesis that the CMB and the earth are at the same rest frame.
Not in mainstream physics models where special and general relativity are absolutely obeyed. There is no evidence other your hypothesis, but special relativity is continuously validated by all experiments and observations.
The $π_0$ has a rest frame, and it decays to two photons. In an event it is not in its rest frame, the photons have to be transformed to the total event rest frame. In no way can one say that the rest frame of the $π_0$ is an absolute frame ( or of any other particle in the event). One has the Lorentz transformations to go from one relative rest frame to another, and the same will be true for the CMB rest frame if it becomes necessary for some research purpose ( as when deriving the velocity of the earth from the dipole distortions which show that the measurements are not done in the rest frame of the CMB).
- 236,935
Special Relativity relies on the assumption that there is no reference frame, Any frame can assume it is a rest frame and another frame is moving relative to it. Special relativity was written before the discovery of the Cosmic Background Radiation and therefore relative motion was the only option available for a theory. In the 19th century physicists were looking for an ether which could provide a rest frame but of course it doesn't exist. However there is a rest frame in the CMB which can be used as a reference for any object moving through space. Using the CMB as a reference you can determine which ref frame is moving faster or slower than another which then gives us the ability to determine which clock is moving faster. This totally conflicts with the symmetry associated with Special Relativity stating any frame can assume it is a rest frame.
