What is the simplest model of chaos governed by a time-independent smooth Hamiltonian on a phase-space with trivial topology?
We know that...
  • With trivial topology, the minimal number of dimension to exhibit chaos with first-order ODEs is three (e.g., the Lorentz system), but these are of course not Hamiltonian.
  • Indeed, time-independent Hamiltonian systems of two phase-space dimensions (one configuration variable) cannot be chaotic because the trajectories follow the fixed-energy surfaces which foiliate the phase space. Thus we need four phase-space dimensions (two configuration variables).
  • There exist time-dependent examples of Hamiltonian chaos in two-dimensional phase space, e.g., the kicked-top.
  • There exist discrete-time non-smooth chaotic maps in two-dimensions that preserve area, e.g., Baker's map.
  • Hadamard's billiards is a time-independent chaotic Hamiltonian system on a four-dimensional phase space. However, it has non-trivial topology (a two-holed donut), exhibiting chaos on account of constant negative curvature.
The double pendulum with equal masses and equal arm lengths has Hamiltonian
$$H(\theta_1,p_1,\theta_2,p_2)= \frac{1}{6} m l^2 \left ( {\dot \theta_2}^2 + 4 {\dot \theta_1}^2 + 3 {\dot \theta_1} {\dot \theta_2} \cos (\theta_1-\theta_2) \right ) - \frac{1}{2} m g l \left ( 3 \cos \theta_1 + \cos \theta_2 \right ).$$
where $\theta_1$ and $\theta_2$ are the angles of the top and bottom arm with respect to the vertical direction, and $p_1$ and $p_2$ are the respective conjugate momenta. This satisfies all our specific requirements except that it is not very simple.
(Note that I am merely extending this question on /r/physics, which lacked the specialization to topologically trivial phase spaces.)
Jess Riedel
  • 3,764
  1. A 1D autonomous system is always Liouville integrable – the Hamiltonian $H$ itself is an integral of motion – so we would have to consider at least 2D to find chaos.
  2. A quadratic potential $V$ yields a linear system, which doesn't exhibit chaos. So the potential $V$ should contain cubic or higher terms.
  3. The potential should mix coordinates (e.g., terms like $x_2^2x_1 $) so that the system isn't separable into two 1D systems.
  4. The Henon-Heiles system in 2D with a potential $V$ containing both quadratic and cubic terms is often given as the standard example of chaos. See e.g. this Phys.SE post.
  5. The homogeneous Henon-Heiles system with a purely cubic potential $V$ is an even simpler system: the Hamiltonian $$H(x_1,p_1,x_2,p_2) = \frac{g}{3}x_1^3 + x_1 x_2^2 + \frac{1}{2}\left(p_1^2 + p_2^2\right)$$ is non-integrable for many value of $g$, including $g \in (-\infty,1)$. See Example 3 (Eq. 5.2) in Section 5.1 of Ref. 1.
References:
  1. J.J. Morales-Ruiz, Differential Galois Theory and Non-Integrability of Hamiltonian Systems, Progress in Math. 179 (1999). [free PDF].
Jess Riedel
  • 3,764
