Given an ensemble i.e, a collection of states and the respective probabilities $\{p_i,|i\rangle\}$, one can uniquely construct the density matrix using $\rho=\sum_ip_i|i\rangle\langle i|$. Is the converse also true? Given a density matrix can we uniquely say which ensemble does it refer to i.e., reconstruct the set $\{p_i,|i\rangle\}$?
When I mean ensembles are different, I mean, can the ensembles be distinguished on the basis of some expectation value of some observable?
SRS
  • 27,790
  • 13
  • 115
  • 365
No, we can't. For example, the ensembles $$\left\{ \left( \frac{1}{3}, |\uparrow\rangle \right), \left( \frac{2}{3}, \frac{1}{\sqrt{2}} (|\uparrow\rangle + |\downarrow\rangle) \right) \right\}$$ and \begin{align*} \left\{ \left( \frac{1}{2} + \frac{\sqrt{5}}{6}, \sqrt{\frac{1}{2} + \frac{1}{2\sqrt{5}}} |\uparrow\rangle + \sqrt{\frac{2}{\sqrt{5}+5}} |\downarrow\rangle \right),\\ \left( \frac{1}{2} - \frac{\sqrt{5}}{6}, \frac{1-\sqrt{5}}{\sqrt{10-2 \sqrt{5}}} |\uparrow\rangle + \sqrt{\frac{1}{2}+\frac{1}{2 \sqrt{5}}}|\downarrow\rangle \right) \right\} \end{align*} both correspond to the same non-degenerate density matrix $$\rho = \left(\begin{array}{cc} \frac{2}{3} & \frac{1}{3} \\ \frac{1}{3} & \frac{1}{3} \end{array} \right).$$ They are completely statistically indistinguishable. (Sorry, there's probably a simpler counterexample.)
tparker
  • 51,104
No. The density matrix $$ \rho=\frac12\left(\begin{matrix}1&0\\0&1\end{matrix}\right) $$ can be e.g. decomposed as $$ \rho=\tfrac12 |0\rangle\langle0|+\tfrac12 |1\rangle\langle1| $$ or $$ \rho=\tfrac12 |+\rangle\langle+|+\tfrac12 |-\rangle\langle-| $$ with $|\pm\rangle=(|0\rangle\pm|1\rangle)/\sqrt{2}$, or an an equal weight mixture of any other two orthogonal states.
Generally, there are infinitely many such decompositions for any non-pure $\rho$, which are related by an isometry.
In particular, the ensemble interpretation is an interpretation. You cannot distinguish different ensembles which are described by the same $\rho$ experimentally, so it does not make sense to say that you have a given ensemble.
