The book Mathematical Physics by Eugene Butkov has, on Chapter 8, the equation for a held string (by held I mean with endpoints fixed and both at the same height) as being $$T\frac{\partial^2 u}{\partial x^2}+F(x)-\rho(x)g=\rho(x)\frac{\partial^2 u}{\partial t^2},$$ where $T$ is the tension, $F$ an external force, $\rho$ the density, $g$ gravity and $u$ transversal (vertical) displacement.
However, the book derives this equation assuming the string deforms little from the horizontal position and the tension is contant. Such assumptions are strong, I think.
Plus, for the stationary case $\frac{\partial u}{\partial t}=0$ it doesn't seem to differentiate between a string hanging by its own weight and a string being pulled by a constant force. And we know these two situations are different since the solution for them is a catenary and a parabola, respectively.
What is the exact equation for a held string?
thedude
  • 668
  • 20
Let $T(x)$ be the modulus of the tension and $T_x$, $T_y$ its horizontal and vertical components.
Suppose a small element of the string having length $ds=\sqrt{dx^2+dy^2}$. Since tension is the only horizontal force, we have $T_x(x)=T_x(x+dx)$ which says $T_x=T_0$ or $T(x)\cos(\theta)=T_0$.
The vertical tension difference is $T_y(x+dx)-T_y(x)=\frac{\partial T_y}{\partial x}dx$. But $T_y(x)=T(x)\sin(\theta)=T_0\tan\theta=T_0\frac{\partial y}{\partial x}$, so $T_y(x+dx)-T_y(x)=T_0\frac{\partial^2 y}{\partial x^2}dx$.
Net vertical force will be $T_0\frac{\partial^2 y}{\partial x^2}dx-F(x)dx-\rho g ds$, where $F(x)$ is assumed downwards. Notice how we take the force to be proportional to $dx$ and not $ds$, assuming it acts only on the horizontal breadth of the element. On the other hand, the mass is definitely proportional to $ds$.
Net force must equal mass times vertical acceleration, $\rho \frac{\partial^2 y}{\partial t^2}ds$.
This gives $$T_0\frac{\partial^2 y}{\partial x^2}dx-F(x)dx-\rho g ds=\rho \frac{\partial^2 y}{\partial t^2}ds.$$
Dividing out by $dx$, we get $$T_0\frac{\partial^2 y}{\partial x^2}-F(x)-\rho g \sqrt{1+\left(\frac{\partial y}{\partial x}\right)^2}=\rho \sqrt{1+\left(\frac{\partial y}{\partial x}\right)^2}\frac{\partial^2 y}{\partial t^2}.$$
I believe this is the exact equation. In the stationary regime, it does give a parabola for a constant force if we ignore the weight, and a catenary for no external force.
Notice however that it only reduces to the usual wave equation $T_0\frac{\partial^2 y}{\partial x^2}=\rho \frac{\partial^2 y}{\partial t^2}$ when we ignore the weight, set $F=0$ and also assume $\sqrt{1+\left(\frac{\partial y}{\partial x}\right)^2}\approx 1$.
Marcel
  • 248
The steady-state catenary arises when $F(x)=0$; the steady-state parabola arises when $F(x)\gg\rho(x)g$. (I just happened to be writing about this here.)
More generally, you could perform an force balance on a differential element of the string to obtain $$\frac{\partial\mathbf{T}(s,t)}{\partial s}+\mathbf{F}(s)-\rho(s)g\mathbf{k}=\rho(s)\frac{d^2 \mathbf{x}(t)}{d t^2}$$ where the parameters in bold are the tension vector $\mathbf{T}$, distributed force $\mathbf{F}(s)$, element position $\mathbf{x}$, and the unit vector $\mathbf{k}$ in the vertical direction and $s$ is the distance along the string. To this you must also add a relationship between $|\mathbf{T}(s)|$ and $ds$. If the string is inextensional, for example, then $s$ is constant. This governing equation is independent of endpoint location and can accommodate forces and displacements in any direction and for a curved string.
You may find this paper interesting: Yong, "Strings, Chains, and Ropes".
