If you were to hold a string at both ends what shape would the string take(in earth's gravity). Obviously this depends on the length of string and the distance you hold the 2 ends apart so let's say that you can only change the distance of the ends from one another on a straight line parallel to the ground. What equation could you use to predict the shape of the string at any given length(of the string) and distance(of the ends)?
Asked
Active
Viewed 88 times
Are you talking about the Catenary shape?
The general equation is
$$ y(x) = a \left( \cosh \left( \tfrac{x}{a} \right) -1 \right) $$
where $y(0)=0$ is the lowest point on the curve, and the parameter $a$ defines how much it bends.
What remains constant along the curve is the horizontal component of tension $H$, which can be used to find $a$
$$ a = \frac{H}{w} $$
where $w$ is the weight per unit length.
jalex
- 3,765
