-2
I was trying to show that: $$[\hat{x}^n,\hat{p}]= i \hbar n \hat{x}^{n-1}.$$
I know from the definition of a pair of a commutator in QM they act on a wave function like this:
$$[\hat A, \hat B] = \hat A \hat B - \hat B \hat A$$
So.. in order to prove this, I apply it some arbitrary wave function $\Psi$ and pull the lever.. (albeit apparently improperly)
$$(\hat p \hat x^n - \hat x^n \hat p )\Psi$$
$$-i \hbar \frac{d}{dx}(x^n\Psi) + ix^n\hbar \frac{d}{dx}(\Psi)$$
Now, the reason why I can't put the $x^n$ in what the derivative operator is applying on the term on the right.. is that because we're assuming that the commutator is not commutative? I thought this applied to the operators themselves, not the resultant function due to those operators. Basically, I thought that while
is not commutative, i.e. that $\hat A \hat B \ne \hat B \hat A$
it isn't apparent to me, then, that
is also not commutative.
The first are operators, the second are elements of a field where associativity is a thing. Let me know if anything about my question is confusing.
sangstar
  • 3,280
Here is another hint to help you out. Write the commutator as \begin{eqnarray*} [p, x^n] &=& p x^{n-1} x - x^{n - 1} x p \\ &=& p x^{n-1} x - x^{n-1}([x, p] + p x) \\ &=& p x^{n-1} x - x^{n-1} p x - x^{n-1}[x, p] \\ &=& [p, x^{n - 1}] x - x^{n - 1}[x, p] \\ &=& [p, x^{n - 1}] x - i \hbar x^{n - 1}. \end{eqnarray*} You have just represented the commutator $[p, x^n]$ with the commutator one power lower. Try to see if you can construct a recursive proof using a similar technique.
FYI: I think you might have written the commutator in your professor's problem backwards. $[p, x^n] = - [x^n, p] = - i \hbar n x^{n - 1}$.
true
  • 31
You need to apply the derivative to both terms inside the braces. The differential operator does not commute with $x$.
$$x \frac{d}{dx} \neq \frac{d}{dx}x = \left(\frac{d}{dx}x\right)+x \frac{d}{dx} $$
This means that
$$-i \hbar \frac{d}{dx}(x^n\Psi) = -i\hbar nx^{n-1}\Psi -i\hbar x^n \left(\frac{d}{dx}\Psi\right)$$
If this doesn't solve your problem, please clarify your question.
thi
  • 420
You can prove the formula by induction, using the propriety of commutators (it is easy to be proven) that $$\left[A B,C\right]=A\left[ B,C\right]+\left[A ,C\right]B $$. Indeed
$$\left[x,p\right] = i\hbar$$ $$\left[x^2,p\right] =x\left[x,p\right]+\left[x,p\right]x = 2 i\hbar x$$ $$\left[x^3,p\right] =x^2\left[x,p\right]+\left[x^2,p\right]x = 3 i \hbar x^2$$
and finally $$\left[x^n,p\right] =x^n\left[x,p\right]+\left[x^{n-1},p\right]x = i \hbar n x^{n-1}$$
Galuoises
  • 153
