Say I want to test if the following function is an eigenfunction of the momentum operator:
$$\psi(x,t) = A\exp{(-\alpha x^2})$$
$$\hat p [\psi(x,t)]= -i \hbar \frac{d}{dx}[A\exp{(-\alpha x^2})]$$
$$\hat p [\psi(x,t)] = -i \hbar (-\alpha 2x) (A\exp{(-\alpha x^2}))$$
$$\implies k = 2i\alpha x$$
This definitely tells me that this is in fact not an eigenfunction of the momentum operator, as this implies the wavenumber $k$ is imaginary and a function of $x$.
However, I don't have a good way of explaining why $k$ can't be imaginary and a function of $x$. Can someone motivate why this is?
sangstar
  • 3,280
An eigenstate of an operator $A$ is by definition a state such that $A\psi=c\psi$, where $c$ is a constant, called the eigenvalue. So not letting the eigenvalue depend on $x$ is simply part of the definition of an eigenvalue.
There is nothing wrong with having an imaginary eigenvalue of momentum. An example would be the wavefunction $\psi=A \exp(\beta x)$.
