I've read the responses to the question `"Lack of inversion symmetry" in crystal?' but I'm still unsure about the meaning of inversion symmetry. Which of the following two dimensional shapes are inversion symmetric?
(a) $\longleftrightarrow$
(b) $\leftharpoonup\rightharpoondown$
(c) $\leftharpoonup\rightharpoonup$
(d) $\nleftarrow\nrightarrow$
I believe it means that the transformation $\textbf{r}\rightarrow -\textbf{r}$ produces the same figure. That is, if you see a point at $(x,y,z)$ you should also see one at $(-x,-y,-z)$.
In this case, if you place the origin at the center of each line, (a),(b), and (d) seem to be inversion symmetric.
mattzhu
  • 288
From a geometrical point of view, inversion symmetry is equal to point symmetry, i.e. invariance under a point reflection.
Shapes (a), (b) and (d) are invariant under point reflection if the point of inversion is located directly between the two arrows. Hence, they are inversion symmetric. Shape (c) is not point/inversion symmetric.
lmr
  • 1,334
