I was working out the math of Gauge Invariance of Schrodinger Equation. Gauge transformations on my $\psi$, and the fields $\vec{A}$, and $A_0$ are \begin{eqnarray*} \psi(x)&\rightarrow& e^{i\alpha(x)} \psi(x)\\ \vec A &\rightarrow& \vec A + \frac{1}{q} \vec\nabla \alpha(x,t)\\ A_0 &\rightarrow& A_0 - \frac{1}{q} \partial_0 \alpha(x,t) \end{eqnarray*}
I need to show that \begin{eqnarray*} i \frac{\partial \psi'}{\partial t}&=& H' \psi'\\ \implies i \frac{\partial \psi}{\partial t}&=& H \psi \end{eqnarray*} where my Hamiltonian is given by \begin{eqnarray*} H=\frac{1}{2m}(p-qA)^2 + qA_0 \end{eqnarray*}
First I try the kinetic energy term, \begin{eqnarray*} (p-qA')^2 \psi' &=& \left(-i \vec\nabla -qA-\vec\nabla\alpha\right)^2 (e^{i\alpha} \psi)\\ &=&\left(i \vec\nabla +qA+\vec\nabla\alpha\right)\left(i \vec\nabla +qA+\vec\nabla\alpha\right) (e^{i\alpha} \psi)\\ &=& \left(i \vec\nabla +qA+\vec\nabla\alpha\right) \left[ ie^{i\alpha}\vec\nabla\psi +qAe^{i\alpha}\psi \right]\\ &=& %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% - \vec\nabla \left( e^{i\alpha}\vec\nabla\psi\right) +i \vec\nabla\left(qAe^{i\alpha}\psi \right) +\left(qA+\vec\nabla\alpha\right) \left[ ie^{i\alpha}\vec\nabla\psi +qAe^{i\alpha}\psi \right]\\ \end{eqnarray*} Now, I am worried about the second term in the last line above, $i \vec\nabla\left(qAe^{i\alpha}\psi\right)$. I assume that should be \begin{eqnarray*} i \vec\nabla\left(qAe^{i\alpha}\psi\right) = iq\left(\vec\nabla A\right)e^{i\alpha}\psi +iqA\left(\vec\nabla e^{i\alpha}\right)\psi +iqAe^{i\alpha}\left(\vec\nabla\psi\right) \end{eqnarray*} My problem isn't solved unless $\vec \nabla A$ is zero. Now, is it zero? What is it anyway? Divergence of $\vec A$ or gradient of $\vec A$? If it's divergence, then that is zero only in electrostatics. If it is a gradient, then it has some other tensor component.
MycrofD
  • 613
The problem is also solved if $\vec\nabla A$ is non-zero. Your last line equals $$ \mathrm e^{\mathrm i\alpha} \left( -\Delta \psi + \mathrm i q\, (\vec\nabla \cdot \vec A)\, \psi + 2 \mathrm i q\, \vec A \cdot \vec\nabla \psi + (q\vec A)^2\, \psi\right) \;. $$
Note that this is the same as $$ \mathrm e^{\mathrm i\alpha}\, ( \vec p - q\vec A ) ( \vec p - q\vec A )\, \psi \;. $$
Edit to respond to comment.
You already did everything correctly in your question, $\vec p - q\vec A$ acts as follows on a wave function $\psi(x)$: $$ (( \vec p - q\vec A ) \psi)(x) = -\mathrm i\hbar\, \vec \nabla \psi(x) - q\vec A(x)\, \psi(x) $$ If you act again from the left with $\vec p - q\vec A$, you just take the inner product. Thinking about this in terms of gradients, divergences etc is possible but not too helpful, it's better to just think in components: $$ (( \vec p - q\vec A )^2 \psi)(x) = \sum_{i=1}^3 \bigl( -\mathrm i\hbar\, \partial_i - q A_i(x) \bigr) \bigl( -\mathrm i\hbar\, \partial_i \psi(x) - q A_i(x)\, \psi(x) \bigr) $$
Noiralef
  • 7,463
