24
It might be just a simple definition problem but I learned in class that a central force does not necessarily need to be conservative and the German Wikipedia says so too. However, the English Wikipedia states different on their articles for example:
A central force is a conservative field, that is, it can always be expressed as the negative gradient of a potential
They use the argument that each central force can be expressed as a gradient of a (radial symmetric) potential. And since forces that are gradient fields are per definition conservative forces, central forces must be conservative. As far as I understand, a central force can have a (radial symmetric) potential but this is not necessarily always the case.
Update Sep 2017: The english Wikipedia has updated its text and now explicitly states
Not all central force fields are conservative nor spherically symmetric. However, it can be shown that a central force is conservative if and only if it is spherically symmetric.[2]
n3rd
  • 393
Depends on what you mean by 'central force'.
If your central force is of the form ${\vec F} = f(r){\hat r}$ (the force points radially inward/outward and its magnitude depends only on the distance from the center), then it is easy to show that $\phi = - \int dr f(r)$ is a potential field for the force and generates the force. This is usually what I see people mean when they say "central force."
If, however, you just mean that the force points radially inward/outward, but can depend on the other coordinates, then you have ${\vec F} = f(r,\theta,\phi){\hat r}$, and you're going to run into problems finding the potential, because you need $f = - \frac{\partial V}{\partial r}$, but you will also need to have $\frac{\partial V}{\partial \theta} = \frac{\partial V}{\partial \phi} = 0$ to kill the non-radial components, and this will lead to contradictions.
It's logical that a field of this form is going to be nonconservative, because if the force is greater at $\theta = 0$ than it is at $\theta = \pi/2$, then you can do net work around a closed curve by moving outward from $r_{1}$ to $r_{2}$ at $\theta = 0$ (positive work), then staying at $r_{2}$ constant, going from $\theta =0 $ to $\theta = \pi/2$ (zero work--radial force), going back to $r_{1}$ (less work than the first step), and returning to $\theta = 0$ (zero work).
riemannium
  • 6,843
Take curl in spherical polar coordinates of a central force ,you will see that since there is no component of the force in the $\theta$ and $\phi$ direction and $f(r)$ doesn't depend on $\theta$ and $\phi$ ,so curl of central force is zero. Hence central forces can be represented as gradient of some scalar,i.e. central forces are conservative.
Paul
  • 3,475
