I see numerous websites talking about how a small balloon is at higher pressure than a big balloon. This is a fun counter-intuitive factoid... unless it isn't a fact at all.
Young-Laplace gives
$$T = \Delta p \frac R2 $$
Which means that for a given tension, increasing the radius does decrease the pressure. But why would the tension be constant? A latex balloon is like a 2D spring, right? So the tension in a inflated spherical balloon should be proportional to the surface area, correct?
$$T \propto R^2 $$
But this gives
$$\Delta p \propto R$$
Which means the bigger the balloon, the higher the internal pressure. Which, again, would be the normal intuition - but it would burst the bubble of some simplified explanations. (har har)
