I can't be sure about the voltage drop issue, but I can certainly provide an explanation of resistance from a quantum-level perspective. Classically, Drude's theory describes resistance in terms of collisions, which is somewhat "simplistic." In quantum mechanics, collisions are better described as scattering, which occurs due to the difference in potential between the incident particle (in this case, the conduction electron) and the finite potential source (the ion cores).
Materials are composed of a periodic lattice structure, where ion cores reside at the lattice points, and free electrons move through the structure. The motion of these electrons isn't entirely "free" because they experience a potential from the ion cores. This potential is periodic, meaning that
V(r)=V(r+a),
where $\mathbf{a}$ is the lattice translation vector.
To understand the behavior of electrons in this periodic potential, we solve the time-independent Schrödinger equation:
$\hat{H}$ψ(r)=Eψ(r),
Due to the periodicity of the potential, the solutions to this equation are Bloch functions, which take the form:
ψ(r)=$u_{\mathbf{k}}(\mathbf{r})$$e^{i \mathbf{k} \cdot \mathbf{r}}$
where $u_{\mathbf{k}}(\mathbf{r})$ is a function with the same periodicity as the lattice, i.e.,
$u_{\mathbf{k}}(\mathbf{r})$=$u_{\mathbf{k}}(\mathbf{r+a})$
and $e^{i \mathbf{k} \cdot \mathbf{r}}$ is a plane wave component. This form of the wavefunction is known as a Bloch wave, and it reflects the fact that electrons in a periodic potential retain some plane-wave-like behavior, but with modulation due to the periodic lattice.
Since the potential is periodic, there is no overall potential difference within an ideal lattice, and thus, quantum mechanical scattering within such a perfect structure does not occur. As a result, no resistance would be present in this idealized situation.
At this point, you might be wondering: if this description is accurate, why do metals exhibit resistance? The answer lies in the fact that no real material is perfectly periodic. There can be defects, such as vacant or distorted lattice points, which break the periodicity. Additionally, dynamical resistance can arise due to the vibrations of ion cores (electron-phonon scattering). These imperfections and vibrations disrupt the periodic potential, leading to quantum mechanical scattering and, consequently, resistance in metals, semiconductors, and insulators. I hope you understand it
