It is a little bit surprising to me that it seems hard to find a detailed, microscopic derivation of the Josephson effect. Generally, you see a hand-waving derivation based on the macroscopic coherence theory (or assumption).
So, could anyone point a relevant paper to me?
I know the paper by Cohen, Falicov, and Phillips, but I cannot make sense of it.
poisson
  • 2,185
As far as I remember, the paper you cite (let me give the full reference)
is about tunneling effect between two superconductors. The Josephson effect is not discussed in this paper, for the simple reason Josephson didn't published his papers at the time of the above paper ...
Perhaps the Josephson effect was first microscopically calculated by Josephson himself ... What about
  • Josephson, B. D. (1962). Possible new effects in superconductive tunnelling. Phys. Lett., 1, 251–253.
  • Josephson, B. D. (1964). Coupled Superconductors. Reviews of Modern Physics, 36, 216–220.
  • Josephson, B. D. (1965). Supercurrents through barriers. Advances in Physics, 14, 419–451.
  • Josephson, B. D. (1968). Weakly coupled superconductors. In Superconductivity (in two volumes), vol. 1 (pp. 423–448). Ed. R.D Parks, Marcel Dekker, Inc.
What do you call microscopic ? Calculating from the tunneling Hamiltonian, or from conservation of the current and overlapping Green's function isn't sufficient for you ?
If you're looking for a textbook, then the tunneling calculation, originated in
can be find in
  • Tinkham, M. (1996). Introduction to superconductivity (second edition). Dover Publications, Inc.
Other important papers, of historical impact, are
  • Andreev, A. F. (1964). The thermal conductivity of the intermediate state in superconductors. Sov. Phys. JETP, 19, 1228–1231. PDF link
  • Andreev, A. (1966). Electron spectrum of the intermediate state of superconductors. Sov. Phys. JETP, 22, 18–23. PDF link
  • Tinkham, M., Blonder, G., & Klapwijk, T. M. (1982). Transition from metallic to tunneling regimes in superconducting microconstrictions: Excess current, charge imbalance, and supercurrent conversion. Physical Review B, 25, 4515–4532.
which start the modern aspects of mesoscopic superconductivity, and quite recent reviews are
FraSchelle
  • 11,033
