21
There are various more or less formal ways of expressing the foundational principles of nonrelativistic quantum mechanics, including both nonmathmatical statements and more rigorous axiomatizations. Recently there have been various people who have treated this from a quantum-computing point of view. Others have explored whether QM can be bent without breaking it. I've given some references at the bottom of this question to some of this kind of work.
But more concretely, I think most physicists would consider the following to be some sort of consensus on an informal list of principles. (Actually, I'd be happy to hear criticisms of this list as well.)
  1. Wavefunction fundamentalism. All knowable information about a system is encoded in its wavefunction (ignoring phase and normalization).
  2. Unitary evolution of the wavefunction. The wavefunction evolves over time in a deterministic and unitary manner.
  3. Observables. Any observable is represented by a Hermitian operator.
  4. Inner product. There is a bilinear, positive-definite inner product on wavefunctions.
  5. Completeness. For any system of interest, there exists a set of compatible observables such that any state of the system can be expressed as a sum of eigenstates.
Question: Does this summary of principles have to be modified for QFT? If so, how? If not, then what is the core difference between these two theories?
References
Kapustin, https://arxiv.org/abs/1303.6917
Mackey, The Mathematical Foundations of Quantum Mechanics, 1963, p. 56ff
Aaronson, "Is Quantum Mechanics An Island In Theoryspace?," http://arxiv.org/abs/quant-ph/0401062
Masanes and Mueller, "A derivation of quantum theory from physical requirements," https://arxiv.org/abs/1004.1483
Hardy, "Quantum Theory From Five Reasonable Axioms," https://arxiv.org/abs/quant-ph/0101012
Dakic and Brukner, "Quantum Theory and Beyond: Is Entanglement Special?," https://arxiv.org/abs/0911.0695
Banks, Susskind, and Peskin, "Difficulties for the evolution of pure states into mixed states," Nuclear Physics B, Volume 244, Issue 1, 24 September 1984, Pages 125-134
Nikolic, "Violation of unitarity by Hawking radiation does not violate energy-momentum conservation," https://arxiv.org/abs/1502.04324
Unruh and Wald, https://arxiv.org/abs/hep-th/9503024
Ellis et al., "Search for violation of quantum mechanics," Nucl Phys B241(1984)381
Gisin, "Weinberg's non-linear quantum mechanics and supraluminal communications," http://dx.doi.org/10.1016/0375-9601(90)90786-N , Physics Letters A 143(1-2):1-2
Sebens and Carroll, "Self-Locating Uncertainty and the Origin of Probability in Everettian Quantum Mechanics," https://arxiv.org/abs/1405.7577
  1. All knowable information about a system is encoded in a ray in a Hilbert space. In QFT, and unlike non-relativistic QM, there is no $|x\rangle$ basis, so you cannot construct a wave-function $\varphi(t,x)=\langle x|\varphi(t)\rangle$ to encode this information. What you can do is encode this information in the so-called correlation functions (cf. Wightman Reconstruction Theorem). You need an infinite number of functions to encode all the information of the system. Equivalently, one may encode this same information in a single functional, either through a functional integral or as a wave functional (cf. 214552).
  2. This is unchanged, except perhaps for the fact that it is usually much more convenient to evolve operators instead of states, because covariance becomes manifest. The abstract Schrödinger equation, $\frac{\mathrm d}{\mathrm dt}|\psi\rangle=-iH|\psi\rangle$ is as valid in non-relativistic QM as it is in QFT (and so is the Heisenberg equation, $\dot A=i[H,A]$). In this sense, the evolution is still unitary, but it is expressed in terms of operators instead of states.
  3. This is unchanged.
  4. This is unchanged, except perhaps for the fact that it is sometimes convenient to artificially enlarge the Hilbert space so as to include "negative norm states", that is, the inner product is relaxed into a sesquilinear form (which agrees with the positive-definite "true" inner product in the "true", physical Hilbert space).
  5. This is unchanged.
Quantum field theory is quantum mechanics applied to Lorentz covariant causal systems. That is, quantum field theory is simply quantum mechanics plus special relativity. Demanding Lorentz covariance and causality constrains the systems you can talk about. For example, a crystal lattice completely breaks Lorentz symmetry, so that's out.
The systems that you can talk about turn out to be those made from Lorentz covariant local quantum fields. This is basically the message of the first 250 pages of Weinberg's The Quantum Theory of Fields. Here is the beginning of Ch.2:
The point of view of this book is that quantum field theory is the way it is because (with certain qualifications) this is the only way to reconcile quantum mechanics with special relativity. [...] First, some good news: quantum field theory is based on the same quantum mechanics that was invented by Schrödinger, Heisenberg, Pauli, Born, and others in 1925-26, and has been used ever since in atomic, molecular, nuclear, and condensed matter physics. [...] [T]his section provides only the briefest of summaries of quantum mechanics [...]
(i) Physical states are represented by rays in Hilbert space. [...]
(ii) Observables are represented by Hermitian operators. [...]
These -- in the full form in the book -- more or less cover your points 1 through 5.
I also recommend Weinberg's talk, What is quantum field theory and what did we think it is?
I think on a pedagogical level thinking of quantum field theory as different from and not just a subset of quantum mechanics may have something to do with that students are first exposed to the Schrödinger equation in the wrong form. The Shrödinger equation is, fundamentally, not a PDE in real-space. It's an ODE in Hilbert space. Correspondingly, one should not start with wavefunctions, but with statevectors, as other answers and comments have pointed out.
Robin Ekman
  • 15,017
All of these postulates continue to hold in relativistic QFT, except that the time-evolution operator is no longer defined by the Schrodinger equation with a nonrelativistic Hamiltonian.
The only one that requires significant new elaboration in the relativistic context is the existence of an inner product. In nonabelian gauge theory, it often a useful calculational trick to formally expand your Hilbert space to a larger state space that includes negative-norm "ghosts." Such a state space is no longer a Hilbert space because its sesquisymmetric bilinear form is no longer positive definite, and is therefore no longer an inner product. But the key point is that you never have to introduce ghosts; they are merely a useful calculation trick, but do not physically exist. You can always do any calculation without invoking ghosts; See here.
tparker
  • 51,104
QFT is just QM...
To expand on Adomas Baliuka's comment: all QFTs that we know how to construct in a mathematically rigorous way do fulfill your 5 axioms. As nicely summarized in AccidentalFourierTransform's answer, the differences to the standard quantum mechanical formulation of a single particle are more in the physical interpretation of the state vector and in the kind of observables you can define on your Hilbert space (eg. you will be measuring the number of particles in a given region of space, rather than measuring the position of a given particle).
In addition, you may want to restrict the term QFT to quantum theories which fulfills additional axioms beyond the basic QM ones, such as locality, causality, (local) Lorentz invariance...
...or some suitable generalization thereof?
But in any case it is important to keep in mind that there aren't that many QFTs that we know how to construct: free fields in any dimension, polynomially-interacting fields in 1+1 and 2+1 dimensions, a couple of other interacting theories in low dimensions, some topological theories (ie. theories that looks like field theories at first glance but turn out to have only finitely many true, physical degrees of freedom),... There are many QFTs that we would like to construct but don't know how, so it remains pretty much an open question in mathematical physics what the "right" axiomatic framework to do QFT should be.
Specifically, the axioms you ask for are likely to break down at least for QFT on a curved, non static spacetime: there, it may no longer be possible to come up with a Hilbert space on which the time evolution could be represented as a unitary transformation. What happens is that when you try write down the evolution you find that it kicks you out of your Hilbert space )-; So you may need to somewhat loosen your definition of what a "state" of your quantum theory is, to guarantee that all states remain valid states as they evolve in time.
A proposal for a more general notion of quantum states are so-called algebraic states (see eg this answer of mine for an elementary introduction). They can be thought as the natural mathematical generalization of mixed states (aka density matrices). Note that even in the context of finitely many degrees of freedom, there are axiomatizations of quantum mechanics in which mixed states are the fundamental object, rather than an afterthought as in the standard formalism. For example, this is the case in the so-called "generalized probability theories" approach, which aims to rederive quantum mechanics from very basic assumptions on measurement processes.
Luzanne
  • 2,102
