It's heard quite often that fundamental particles (photons, quarks, etc) act as both particles and waves.
Now, I'm looking at it from a Quantum Field perspective. Is this localized energy ripple what the wave is? And is the fact that it is localized make it a particle?
Quantum Field
As shown in the GIF above, there is a red lattice, which is a quantum field. This is an oscillating ripple. Is this the wave nature of the particle? Is that what causes the result of Thomas Young's double slit experiment? Also, there is a green layer representing the particle's position, representing the disturbance in the quantum field as a particle. Is this the explanation for the photoelectric effect?
Ultimately, is this the explanation for the wave-particle duality?
5 Answers5
19
No, this is not at all how quantum field theory works.
  1. A "quantum field" does not have a definite value at any time, it is an operator in the quantum theory, not something that has a fixed numerical value, therefore representing it as a lattice as you have done does not reflect the quantum nature of the field. This is the classical picture of the field, just like a point particle is the classical picture of the electron, not its quantum picture.
  2. The quantum field and the particle states are different things - the field is an operator and the particle is a state in the quantum theory. You can use (parts of) the quantum field operator to create particles, but the notion of particle is much more elusive than it being a simple ripple in a classical field. For more on this see this answer of mine on real particles and this question and its answers on virtual particles.
  3. The "wave-particle duality" is, in any case, a somewhat vague notion that has no real formal counterpart in modern quantum mechanics. Quantum objects are just that, quantum objects. They have aspects of waves (e.g. they can "interfere", they can obey wave-like equations, they "spread") and they have aspects of particles (e.g. they can (but not must be) localized at "points", they have mass) but they are neither. And I'm sure you can find quantum behaviour that you'll not be able to attribute to either a wavy or a particle nature, such as Bell experiments about entanglement (which cannot be explained classically, and hence any attempt to explain them with a particle or wave picture must necessarily fail).
ACuriousMind
  • 132,081
Here is an answer by an experimentalist:
Quantum field theory is a necessary mathematical tool in order to be able to calculate interactions between elementary particles , as defined presently in the standard model of particle physics.
This introduction in the wiki article is sufficient for a broad picture.
In theoretical physics, quantum field theory (QFT) is the theoretical framework for constructing quantum mechanical models of subatomic particles in particle physics and quasiparticles in condensed matter physics. QFT treats particles as excited states of the underlying physical field, so these are called field quanta.
For the QFT of particle physics, each particle/quantum-mechanical-entity in the table defines a field, a photon field, an electron field etc which covers all the phase space. This field is the ground state of the corresponding free particle solution of the appropriate equation, the Dirac for the electron, the quantized Maxwell for for the photon etc . These fields acquire a physical meaning when operated with the number operator, which is a differential operator and creates or annihilates a particle at that (x,y,z,t) where the ground state/field is defined.
So in your diagram, if one of the axis is space, the other is time , and when going up to the green level one electron is created with a creation operator, and going down it is destroyed with a destruction operator, and moves to the next time position. A consistent wave packet in (x,t) would move in the x direction like a bump. See the answer here for particles as wavepackets where one has to enter in the mathematics.
The wave nature is evident in the calculated probability distributions for a given reaction, and these show wave behavior because the underlying ground levels on which calculations and expansions are carried out are wavefunction solutions of quantum mechanical equations. QFT is a method of organizing the perturbative expansion which approximates the exact solutions of a scattering problem, but it is based on the postulates of quantum mechanics.
So the wave nature does not come because of QFT structures,but because the QFT mathematical structures are built on wavefunctions. So a similar plot would illustrate the wavepacket nature of particle representations in QFT, but the particle/wave duality comes from the nature of the wavefunctions describing the ground state, on which the quantum field creation and annihilation operators work.
anna v
  • 236,935
No. Wave-particle duality is due to the fact that, in quantum mechanics, not all particle properties commute. This ultimately means properties of particles can be described using a wavefunction (an expansion of the quantum state in some basis of properties). This function maps properties to probability amplitudes, and permits interference patterns and other strange wave-like phenomena loosely termed "wave-particle duality".
Quantum field theory has an analogous formalism. The properties of fields do not all commute, and so field properties can be described using a wavefunctional.
The commutation relations of quantum theory are a nomological ingredient of quantum theory and are not explained by some deeper physical principle.
DJames
  • 411
According to QFT there's no wave, and there are no particles at all. There are only and only quantized fields and they can unify the two contradictory sides of the coin, the wave-particle duality enigma or paradox is completely solved within the framework of QFT. The problem was firstly posed by two theorems by Einstein in his famous Photoelectric paper.
1-Computing the number of microstates of the radiation field using Planck's entropy that was compatible only with the existence of a photon gas(particles)
2-Energy fluctuations that consisted of a wave-like contribution and a corpuscular(particle-like) contribution.
And the first rigorous solution was presented by Jordan who invented the idea of Quantum Fields.
Bastam Tajik
  • 1,310
-3
First, 'wave' is a form (descriptor) and particle is an entity/object, so you and everyone else are comparing incomparables. That said, a particle does have a form which we can describe as"field-form" [something extending in {occupying} space (volume)]. Just as a wave extends in time (wave cycles reside/occupy time) so a particle extends in [occupies] space. For electrons in motion, why cannot the rest mass have the 'field-form' character and the electron's kinetic energy have the [oscillating] waveform character? Which character dominates depends upon rest mass quantity versus kinetic energy quantity.
As for asking QFT to determine the actual, physical presence of waveform or field-form ['particle'] for moving masses, here is a quote from Stanford Encyclopedia of Philosophy to consider: "one reason why the ontological interpretation of QFT is so difficult is the fact that it is exceptionally unclear which parts of the formalism should be taken to represent anything physical in the first place."
Short answer, QFT doesn't care about physical entities; it postulates entities [fields] it can manipulate mathematically to satisfy experimental results [the ether theory can do the same thing; it too can account for space contraction and time dilation].
Suggest you google 'einstein' and 'method' since E had similar critiques of the duality.
Chris
  • 17,377
