I am trying to understand how to use the Euler-Lagrange formulation when my system is subject to external forces. Consider the system pictured below:
my system
Let's define the lagrangian, as always, as $L = K - V$, where the external forces play no roll at all.
If $F_x \equiv F_\theta \equiv 0$, the standard Euler-Lagrange formulation for the system would be:
$$\frac{d}{dt} \left ( \frac{\partial L}{\partial \dot x} \right ) - \frac{\partial L}{\partial x} = 0$$
$$\frac{d}{dt} \left ( \frac{\partial L}{\partial \dot \theta} \right ) - \frac{\partial L}{\partial \theta} = 0$$
Now, according to a paper I am reading, if we include the force $F_x(t)$ (i.e. $F_x(t) \not \equiv 0$), the first equation should now be replaced by
$$\frac{d}{dt} \left ( \frac{\partial L}{\partial \dot x} \right ) - \frac{\partial L}{\partial x} = F_x(t)$$
This makes sense, of course, but I'm trying to understand how to extend this procedure to different forces, and I am a bit lost. So, for example, let's now include the force $F_\theta(t)$. How would the Euler Lagrange equations change to account for it?
Diracology
  • 18,168
LGenzelis
  • 279
If the force is not derived from a potential, then the system is said to be polygenic and the Principle of Least Action does not apply. However, the Euler-Lagrange equations can be derived from d'Alembert Principle.
If we decompose the applied (or specified) forces acting on particle $\alpha$ into monogenic (derived from a potential), $\vec F_\alpha^m$ and polygenic forces, $\vec F_\alpha^p$, then d'Alembert Principle reads, $$\sum_\alpha(\vec F_\alpha^m+\vec F_\alpha^p-\dot{\vec p}_\alpha)\cdot\delta\vec r_\alpha=0.$$ The next step is to write this equation in terms of generalized coordinates $q_i$. The result is the following equation of motion $$\frac{d}{dt}\frac{\partial T}{\partial \dot q_i}-\frac{\partial T}{\partial q_i}=Q_i^m+Q_i^p,$$ where $$Q_i^p\equiv\sum_\alpha\vec F_\alpha\cdot\frac{\partial \vec r_\alpha}{\partial q_i}.\tag1$$
The monogenic force can be obtained from a potential $V$, $$Q_i^m=-\frac{\partial V}{\partial q_i},$$ hence the equation of motion $$\frac{d}{dt}\frac{\partial T}{\partial \dot q_i}-\frac{\partial T}{\partial q_i}+\frac{\partial V}{\partial q_i}=Q_i^p.$$ If the potential does not depend on velocities, then this equation can also be written as $$\frac{d}{dt}\frac{\partial L}{\partial \dot q_i}-\frac{\partial L}{\partial q_i}=Q_i^p,\tag2$$ where $L=T-V$ is the Lagrange function. Equation (2) is the one you shall use, together with Eqn. (1) to obtain the generalized force $Q_i^p$.
Edit:
Let's now apply this approach to the example posed in the question. There are two external forces, which can be written as $\vec F_1 = [F_x(t) \; , 0]^T$ and $\vec F_2 = [0 \; , -F_\theta(t)]^T$. The position of each body (regarded as a point mass) is $\vec r_1 = [x \; , 0]^T$ and $\vec r_2 = [x + l \sin \theta \; , -l \cos \theta]^T$. Therefore, we calculate $$Q_1^p = \vec F_1 \cdot\frac{\partial \vec r_1}{\partial x} + \vec F_2 \cdot\frac{\partial \vec r_2}{\partial x} = F_x(t)$$ and $$Q_2^p = \vec F_1 \cdot\frac{\partial \vec r_1}{\partial \theta} + \vec F_2 \cdot\frac{\partial \vec r_2}{\partial \theta} = -F_\theta(t) l \sin \theta .$$
Finally, the corresponding Euler-Lagrange equations are $$\frac{d}{dt}\left(\frac{\partial L}{\partial \dot x}\right )-\frac{\partial L}{\partial x}= F_x(t)$$ $$\frac{d}{dt}\left(\frac{\partial L}{\partial \dot \theta}\right )-\frac{\partial L}{\partial \theta}=-F_\theta(t) l \sin \theta,$$ where $$L = T - V = \frac{M}{2} \left\lVert\dot {\vec r_1}\right\rVert^2 + \frac{m}{2} \left\lVert\dot {\vec r_2}\right\rVert^2 + m g l \cos \theta .$$
LGenzelis
  • 279
Diracology
  • 18,168
