I'm currently studying Lagrangian mechanics, and in the process, I've met the following equations in a couple of proofs. $$ \frac{\partial \mathcal{L}}{\partial q_i} = \dot p_i $$
$$ \frac{\partial \mathcal{L}}{\partial \dot q_i} = p_i. $$ Where do they come from? and do they hold indefinitely? Or only under certain conditions? Are there any general ones?
The relation below is simply the definition of the generalized momentum. It requires no proof, as is true by definition:
$$ p_i = \dfrac{\partial \mathcal{L}}{\partial \dot{q_i}} $$
Now according to Lagrangian Mechanics, we aim to find the equation of motion $q(t)$ which minimizes the action $S = \int \mathcal{L}(q, \dot{q}, t) \cdot dt$; note that we are fixing the starting points and ending points of the trajectory to specific points (i.e. what trajectory $q(t)$ which starts at $(q_1, t_1)$ and ends at $(q_2, t_2)$ minimizes $S[q]$). Turns out action is minimized if and only if this equation is satisfied:
$$ \dfrac{\partial \mathcal{L}}{\partial q} = \dfrac{d}{dt} \dfrac{\partial \mathcal{L}}{\partial \dot{q}} $$
$$ \therefore \dfrac{\partial \mathcal{L}}{\partial q_i} = \dot{p}_i $$
So the latter equation is a ramification of the axiom which states $S[q]$ needs to be minimized. The derivation of this equation is proven in many physics or functional analysis textbooks.
Edit: Your textbook should prove this itself, but you can also look into theorem 6.1 of this file https://scholar.harvard.edu/files/david-morin/files/cmchap6.pdf
The intuition behind the definition: $$ p_i = \frac{\partial L}{\partial \dot{q}_i} $$ is that for a single massive particle under some position-dependant potential energy, $V(\mathbf{q})$ and taking as generalized coordinates the cartesian coordinates (let's make it 1D and $q = x$ for simplicity): $$ L = T - V = m\frac{\dot{q}^2}{2} - V $$ So really: $$ \frac{\partial L}{\partial \dot{q}} = m \dot{q} = p $$ it coincides with linear momentum in this case. But really, it's a definition that generalizes this notion even when that's not equal to linear momentum. The second equation comes from the Lagrange equation itself: $$ \frac{d}{dt}\frac{\partial L}{\partial \dot{q}} = \dot{p} = \frac{\partial L}{\partial q} $$
Petrini
  • 322
