15
I'm pretty sure that you can't take a magnifying glass and make it focus to a point that is hotter than the surface of your light source. For example, when you're outside trying to fry ants with your magnifying glass, it's impossible to get it hotter than 5,000 C (the temperature of the surface of the sun). My dad was arguing with me about it because he didn't see why this was true. My easiest argument was that the 2nd law of thermodynamics prevents this from happening because heat can't flow passively from a place of lower energy/entropy to a place of higher energy/entropy. He didn't buy it, saying that there wasn't anything preventing the light from focusing to a hotter point.
So I was wondering, are there some laws of optics that prevent this from happening? Or alternatively, is there a way to show that you could build a perpetual motion machine from this? Any help is appreciated.
"... is there a way to show that you could build a perpetual motion machine from this?"
Yes. Focus the radiant heat from a thermal reservoir onto a spot that is hypothesized to be raised to a higher temperature through its concentration into a smaller area. Now connect heat engine - a Carnot engine - between the hot spot as the engine's heat intake and the original reservoir as the heat exhaust. Now the engine will run, outputting work. Your hypothesis means that you have an heat engine system spontaneously converting the heat in the thermal reservoir to work and there's your perpetual motion machine (of the so-called second kind).
Obligatory in any conversation of this kind is Randal Munroe's Fire From Moonlight article.
One way to understand all this is to note that optical systems are reversible, so that if light can pass from point A at the input to point B at the output, light can equally well go the other way. So if a hot body directs its radiant heat at another object through a lens system, the temperature of the latter will naturally begin to rise. That means that the second body will radiate back to towards the first body. If the second body became hotter than the first, it would be returning a higher heat power to the first along the reverse paths whence the incident heat came. Therefore, heat transfer will stop before the second body reaches the temperature of the first.
The second law of thermodynamics in optics is equivalent to the non-decreasing of étendue, which is the volume of a system of rays representing a light field in optical phase space and thus a measure of entropy. If étendue cannot be decreased, this means that density of rays in phase space cannot be increased; in turn this means that the divergence angles of a set of rays must increase if the area they pass through is shrunken down. This means that the light from any point on a hot body cannot be made brighter at the point where it reaches the target body.
This also is why a laser works differently if we try to reason as above. If energy reaches a body through a laser, the incident light paths taken have near to zero étendue - there's hardly any beam spreading at all. The second body will get hotter and hotter, but the radiant heat from the hot second body is all spread out in all directions (this is fundamental to blackbody radiation - there's no such thing as collimated blackbody radiation). So hardly any of the radiated light is accepted back along the extremely narrow range of paths back to the laser. Laser light is highly nonequilibrium light - it is the optical equivalent of thermodynamic work, rather than heat.
As well as by thermodynamic arguments, one can show that étendue is conserved very generally in passive optical systems using the Hamiltonian / symplectic geometry formulation of Fermat's principle. I discuss this in more detail in this answer here. Fermat's principle means that propagation through inhomogeneous mediums wherein the refractive index (whether the material be isotropic or otherwise) varies smoothly with position corresponds to Hamiltonian flows in optical phase space; mirrors, lenses and other "abrupt" transformations as well as smooth Hamiltonian flows can all be shown to impart symplectomorphisms on the state of the light in phase space, which means that they conserve certain differential forms, including the volume form. All these things mean that the volume of any system of rays in optical phase space is always conserved when the rays are transformed by these systems. This is the celebrated Liouville Theorem.
There is a clunkier but more perhaps accessible way to understand all this in optics. We linearize a system's behavior about any reference ray through the system, and write matrices that describe the linear transformation of all building block optical systems. It may seem that linearization involves approximation and thus something not generally true, but hold off with this thought - this is not the case. This is the Ray Transfer Matrix method and these linear transformations describe the action of the system on rays that are near to the reference (the "chief ray") ray of the light field in optical phase space. These matrices act on the state $X$ of a ray at the input plane of an optical subsystem:
$$X = \left(\begin{array}{c}x\\y\\n\,\gamma_x\\n\,\gamma_y\end{array}\right)\tag{1}$$
where $(x,\,y)$ is the position in the input plane of the ray, $(\gamma_x,\,\gamma_y)$ are the $x$ and $y$ components of the direction cosines of the ray's direction and $n$ is the refractive index at the input plane at the reference ray's position. The quantities $n\,\gamma_x$ and $n\,\gamma_y$ are the optical momentums conjugate (in the sense of Hamiltonian mechanics) to the positions $x$ and $y$; interestingly, they are indeed equivalent (modulo scaling by the constant $\hbar\,\omega/c$) to the $x$ and $y$ components of the photonic momentum $\hbar\,\vec{k}$, where $\vec{k}$ is the wavevector, but this fact is an aside. (1) describes our points in optical phase space.
Now we write down the matrices that represent the linearized action of every optical component we can think of; for example, a thin lens (representing the paraxial behavior of an optical surface) will impart the matrix:
$$\left(\begin{array}{cccc}1&0&0&0\\0&1&0&0\\-\frac{1}{f}&0&1&0\\0&-\frac{1}{f}&0&1\end{array}\right)$$
If you study this matrix's action, you'll see that it transforms a collimated beam into one that converges to a point a distance $f$ from the input plane.
A key point to take heed of is that this matrix has a determinant of 1. If you go through the list of every possible passive optical component, you'll find that the matrices that describe their paraxial behavior all have unity determinant (they are unimodular). So they all multiply together to give a unimodular ray transfer matrix of the overall system built from these subsystems chained together.
This determinant is the Jacobian of the general, non-linearized, non approximate transformation that the system imparts on any system of rays. We can imagine recalculating a matrix from every neighborhood of every chief ray in an arbitrary, noninfinitessimal volume of rays in phase space. These matrices will all be unimodular, so what we've shown is the key idea:
The Jacobian $J(X)$ of the transformation wrought by any passive optical system is unity at all points $X$ in phase space.
This means that if we work out the volume $\int\mathrm{d}V$ of a system of rays in phase space, then the volume of their images $\int\,J(X)\,\mathrm{d}V$ will be exactly the same for any passive optical component. So we've shown the exact version of the law of conservation of étendue for optics without needing the full machinery of symplectic geometry and Hamiltonian mechanics.
Selene Routley
  • 90,184
  • 198
  • 428
You probably mean heat can't flow passively from a place of lower temperature to a place of higher temperature.
This is true for conduction of heat via microscopic chaotic motion. More precisely, it can happen on the microscopic scale, as a fluctuation, but macroscopic transfer is extremely improbable, so we consider it as impossible.
But for other modes of transport, with large scale fluctuations, we can't impose such condition on all individual heat transfers. "Heat" (internal energy) can be transported from a colder body to a hotter body e.g. by a fluid. For example, when boiling water, a cold water element on the water surface moves down towards the hotter bottom of the kettle, heats up and only then moves up away from the hot bottom. But while it went down, it carried heat from the colder region to the hotter region. On global account, heat from the hot bottom is being lost to the surrounding air, which is colder, but locally, such interesting heat transfers (from colder to hotter regions) can happen. These local interesting transfers can happen in a process far from equilibrium, which is maintained by the net energy flux from the hotter to the colder region.
So it is quite theoretically possible that while a spontaneous large energy flux from the hotter Sun surface to the colder outer space (and Earth surface) is happening, some small part of the incoming radiation energy on Earth can be used by a special machine to heat up a small ball into a temperature higher than the Sun surface has (usual materials melt at such temperatures and normal pressure, so this will require keeping the ball together somehow, e.g. using large pressure). It is hard or impossible to do this while being restricted to simple lenses and mirrors. But it is not impossible when we are allowed to use more than that, in particular, we can use solar panels, a battery, and an arc welder.
We would not get a machine of 2nd kind, violating 2nd law, because there is a colder reservoir (Earth) which takes in most of the unused heat and allows us to operate such special machine.
A machine of 2nd kind means that net heat the machine takes in from the reservoir (the heat taken in one cycle minus the heat put back in it in one cycle) is converted to work. Such machine violates 2nd law. But such machine of 2nd kind isn't made possible by our special machine creating a hotter spot. The latter is allowed to use Earth and outer space as colder reservoirs and put lots of heat in them. 2nd law only prevents conversion of all radiated energy of the Sun into work, or using it all to heat up a hotter body. It does not prevent conversion of some of it into work, or using some of it to heat up a hotter body, while dumping the rest into a colder reservoir.
