-2
while i have tried reading explanations for why newtons third law doesn't mean objects can't move such as this one: With Newton's third law, why are things capable of moving? I still do not understand how to apply them to the system I'm about to describe:
(Suppose the system is in space so friction isn't present)
Force F is pushing object A, object A thus pushes object B with force equal to F. According to newtons third law object B will exert an equal force on object A in the opposite direction. So now on Object A, two equal forces are acting in opposite directions, so it should not move. my question is why does object A end up moving after all?
wonder
Object B does not exert a force equal to F. By Newton's Third Law, Object B exerts a force on A equal to the force exerted by A on B. That's what Newton's Third Law states.
If the entire system were not moving, we could then point out that the force exerted by B must match F, but in reality, the system will accelerate. A will push on B with less force than F, and thus B will push on A with less force than F too. The two objects will accelerate together, and the forces will distribute such that if you look at the forces on B from A, it's just enough to accelerate block B at their combined acceleration rate. And if you look at A, you'll find the difference between the force F and the force of B on A will also be exactly the right amount to accelerate B at the same rate.
(We know this beacause we intuitively know the blocks will move together, accelerating at the same rate. Proving that this works without making that intuitive leap involves a bit more physics. You'll learn that eventually!)
Cort Ammon
  • 53,814
  • 103
  • 176
