11
The phase difference can be measured but is it possible to measure the instantaneous phase of the electric field in light wave at one position?
cat's eye
  • 355
Yes, for a classical field (e.g. a large photon number, coherent state), in principle the phase can be measured in the sense that one can in principle observe that the electric (magnetic) field at a given point oscillates sinusoidally with time and one can measure at what times the field is zero and when it reaches its maximums.
If you don't believe this for light, simply imagine the experiment with microwaves, or radiowaves. Phase locked loops have been synchronizing oscillator circuits with incoming radio waves for the best part of a hundred years.
So at optical frequencies, the difference is one of technology only, not physics. Optical phase locked loops now exist and realize coherent modulation schemes over optical fiber communication links.
If you mean by your question the phase of a quantum state of light, then, of course, the state is a ray in projective Hilbert space and is invariant with respect to multiplication by a global phase. No meaning can therefore be given to the absolute phase of a quantum state. Phase differences between the complex amplitudes of base states in superposition are meaningful, and these determine interference effects and the evolution of the quantum state.
Classical and quantum phase are quite distinct, however, and don't simply merge through a "correspondence principle" in a large photon number limit. To understand the difference between them, and the lack of a "correspondence principle", consider a photon number coherent state $\psi(\alpha,\,t)$ of the quantum harmonic oscillator:
$$\begin{array}{lcl}\psi(\alpha,\,t) &=& e^{-i\,\frac{\hbar}{2}\,\omega_0\,t}\,\exp\left(\alpha\,e^{-i\,\hbar\,\omega_0\,t}\,a^\dagger - \alpha^\ast\,e^{+i\,\hbar\,\omega_0\,t}\,a\right)\,|0\rangle \\&=& e^{-i\,\frac{\hbar}{2}\,\omega_0\,t}\,e^{-\frac{|\alpha|^2}{2}}\,\sum\limits_{k=0}^\infty\,\frac{\alpha^k}{\sqrt{k!}}\,e^{-i\,k\,\hbar\,\omega_0\,t}\,|k\rangle\end{array}\tag{1}$$
which is a superposition of Fock (number) states beating together as their relative phases oscillate at different frequencies. Suppose we measure the photon number with the number observable $\hat{n}=a^\dagger\,a$; its mean $\langle\psi|\hat{n}|\psi\rangle$ is constant at $|\alpha|^2$ (indeed, so are all the moments $\langle\psi|\hat{n}^k|\psi\rangle;\,k\in\mathbb{N}$ and by calculating them, one can show that the photon number is Poisson distributed with mean $|\alpha|^2$). However, suppose we measure the position with the position observable $\hat{x}= \sqrt{\frac{\hbar}{2}\frac{1}{m\omega}}\,(a^\dagger + a)$ or the momentum with observable $\hat {p}= i\sqrt{\frac{\hbar}{2}m\omega}\,(a^\dagger - a)$; the means of these measurements $\langle \psi|\hat{x}|\psi\rangle$, $\langle \psi|\hat{p}|\psi\rangle$ are phase-quadrature, time harmonic functions:
$$ \langle \hat{x}(t) \rangle = |\alpha| \sqrt{\frac{2\,\hbar}{m\,\omega}} \cos (\arg(\alpha) - \omega_0 t)$$ $$ \langle \hat{p}(t) \rangle = |\alpha| \sqrt{\frac{2\,m}{\hbar\,\omega_0}} \sin (\arg(\alpha) - \omega_0 t)\tag{2}$$
and the phase of these quantites, i.e. $\arg(\alpha)$, is the classical phase. Take heed that we can multiply the state $\psi$ in (1) by any wildly time-varying quantum phase $e^{i\,\varphi(t)}$ we like and the results of the above calculations will be unchanged; the quantum phase disappears under the multiplication of the state and its complex conjugate in the calculation $\langle \psi|\hat{X}^k|\psi\rangle$ of any moment of any observable $\hat{X}$. Note that the classical phase is perfectly well defined for any, arbitrarily small mean photon number coherent state (it's simply that for $\alpha$ very small, you'll need many measurements on the same state to measure it, whereas a single measurement will do for laser-sized values of $\alpha$).
For measurement of classical phase of light, see Emilio Pisanty's answer here describing the relevant experimental technology in the Physics SE thread Have we directly observed the electric component to EM waves?.
Also, one can indeed define an observable for the classical phase of a quantum state, although it's tricky; an influential quantum optics researcher has written a whole book on the subject:
Stephen M. Barnett & John A. Vaccaro, "The Quantum Phase Operator: A Review"
(Stephen M. Barnett, along with Bruno Huttner, was one of the first people to work out a fully quantized theory of the electomagnetic field in a dielectric (in this paper here)).
Selene Routley
  • 90,184
  • 198
  • 428
Yes, of course it is possible to measure phase. Holography works by combining a source wave with a reflected-light wave and where the phases match (zero degrees) the light intensity is high (and darkens the film), and where the phases mismatch (180 degrees) the light intensity is minimum, and the film stays transparent. That hologram image, then, captures the reflected-light phase (and reconstruction of the image afterward is therefore possible by illuminating the film with a copy of that original source wave).
Whit3rd
  • 10,853
Yes, since 2003 we can measure the electric field wave of (visible) light pulses using attosecond light pulses. You may have heard that the 2023 Nobel Prize for physics was awarded "for experimental methods that generate attosecond pulses of light". One of the first applications was to measure the electric field wave of a very short (sub-5fs) light pulse published as "Direct Measurement of Light Waves", see References below.
What we measure is the phase of a (short) light pulse with respect to the pulse envelope (it is called the carrier-envelope phase).
Requirements
This technique requires that the light wave to be measured is
  1. a pulse that
  2. is very short, and
  3. intense, and
  4. can be repeatedly generated with precisely the same wave form (the difficult part).
Requirement #1 is because the pulse envelope serves as the reference against which we measure the phase (of the carrier wave).
Requirement #2 is because we use the pulse to generate a single (isolated) attosecond "probe" pulse and to get an isolated probe pulse (as opposed to a train of probe pulses which would generate ghost images) we need the to-be-measured pulse to have only a "few" optical wave cycles (<3).
Requirement #3 is because we need sufficient field strength to streak electrons (see next chapter)
Requirement #4 is because the technique is not a single-shot technique but requires scanning of a probe pulse across the to-be-measured pulse wave form.
Technique
Basically we use the to-be-measured light wave to "streak" (accelerate or decelerate) electrons that were previously emitted by the attosecond pulse. We measure the (streaked) kinetic energy of those electrons as we scan the short attosecond pulse over the longer (but still ~5fs short) to-be-measured pulse to reproduce its electric field waveform.
To make this work, the probing attosecond pulse must be shorter than the period of the to-be-measured pulse, otherwise we would not be able to resolve its waveform (it would "wash out").
The probing attosecond pulse must be precisely synchronized to the to-be-measured pulse. This is fulfilled by generating the attosecond pulse from a copy of the to-be-measured pulse (using a beam splitter).
Further Reading
For a detailed and scientifically precise explanation please read the reference cited below.
For a scientific video see the first 30 minutes of https://youtu.be/KbEg90h4qTU?si=J1lsByPg5-WSIODP
Layman explanation by Ferenc Krausz: https://youtu.be/6ZIUJb85BAQ?si=pRUNy2b6YITBgWLE
References
E. Goulielmakis et al., Direct Measurement of Light Waves Science 305, 1267-1269 (2004). https://doi.org/10.1126/science.1100866 Download: https://mediatum.ub.tum.de/doc/1579427/document.pdf
-1
No if you meant visible light. We can measure phase directly only when EM wave's frequency is lower than 400GHz. Because fastest transistor we made is about 400GHz. But visible light have frequency 400–790THz. We need 1000x faster transistor to measure phase of visible light.
