Is there any program which attempts at unifying quantum mechanics and gravity rather than unifying quantum field theory and gravity?
Motivation
We use the heisenberg picture to define velocity $\hat v$:
$$ \hat v = \frac{dU^\dagger x U}{dt} = U^\dagger\frac{[H,x]}{- i \hbar}U$$
where $U^\dagger$ is the unitary operator and $H$ is the Hamiltonian.
Now we can again differentiate to get acceleration $\hat a$:
$$ \hat a = \hat U^\dagger\frac{[[\hat H, \hat x], \hat x]}{-i \hbar} \hat U = \hat U^\dagger\frac{(\hat H^2 \hat x + \hat x \hat H^2 - 2\hat H \hat x \hat H)}{\hbar^2} \hat U $$
We can simplify the calculation by splitting the Hamiltonian into potential $ \hat V $ and kinetic energy $ \hat T $: $\hat H = \hat T + \hat V$
By noticing (one can also calculate this) that the acceleration of an object in a constant potential is $0$:
$$ \hat 0 = \hat T^2 x + x \hat T^2 - 2 \hat T \hat x \hat T $$
We also know $ [\hat V, \hat x] = 0 $ as potential is a function of position. Thus, we can simplify acceleration as:
$$ \hat a = \hat V \hat T \hat x + \hat x \hat T \hat V - \hat V \hat x \hat T - \hat T \hat x \hat V $$
Note this acceleration operator also commutes with position:
$$ [\hat a , \hat x ]=0$$
Now from the equivalence principle we know that the effect of acceleration is indistinguishable from gravity. Hence, even the quantum mechanical version of the Riemann curvature tensor must also commute with position. Note, this argument does not work for high energies (QFT) as acceleration does not make sense in QFT.
drewdles
  • 1,207
General relativity is a field theory, so any quantization of it is an example of QFT rather than non-relativistic QM. However, Newtonian gravity's quantization requires no QFT-level treatment; you just use a $1/r$ potential, as with the quantum hydrogenlike atom's electromagnetism. You can even use a $V=mgh$ approximation. There have been studies of cold neutrons falling in Earth's gravity, e.g. https://www.researchgate.net/profile/T_Jenke/publication/223269839_QuBounce_the_dynamics_of_ultra-cold_neutrons_falling_in_the_gravity_potential_of_the_Earth/links/57dbd38e08aeea1959355e6e.pdf & https://arxiv.org/pdf/1103.1015 .
J.G.
  • 25,615
