Using multiple polarizers (some of them beam-splitting to minimize losses) and a spiral alignment (more like this), one can, I gather, set the polarization of the majority of passing photons to a desired orientation.
What does this do to such photons' polarization-entangled twins?
Do they remain entangled?
What becomes of their polarization? Randomized?
kaay
  • 123
There's multiple ways to affect the polarization of a photon.
  • The mechanism you in the answer you lined to is a projective measurement of the polarization of one photon, followed by further projective measurements on that same photon. In that case, only the first measurement has any bearing on subsequent measurements of the polarization of the entangled counterpart.
    Thus, if the photons are in the polarization singlet state $|HV\rangle - |VH\rangle$, and the initial polarizer put in front of photon 1 is vertical (to be followed by diagonal and horizontal ones) then (in coincidence with a measurement of photon 1) the other photon will always be detected with a horizontal polarization.
  • On the other hand, there are mechanisms that act as unitaries, the simplest of which is a half-wave plate or a stretch of optically-active medium. This will have no effect on the entangled counterpart, or on the entanglement between them.
It's also important to note that there is a wide variety of types of entanglement between photons; this can be in polarization (so e.g. $|HV\rangle - |VH\rangle$ is different from $|VV\rangle + |HH\rangle$) but they can also be entangled in frequency, timing, angular momentum, direction, and so on, all of which are independent of polarization.
It's also a bit of a misstatement to say that your 'spiral' arrangement of polarizers sets the polarization of the 'majority' of the photons: it will determine the polarizations of all the photons that pass, but it will have a transmittance of 12.5%.
Emilio Pisanty
  • 137,480
