When I was reading the original paper about Runge-Gross theorem (Phys. Rev. Lett. 52, 997 (1984)), I saw $\hat{\psi} $ operator notation.
I've never seen these notations from my QM text, and I'm confused now.
In this paper, each operator consisting of the Hamiltonian $ \hat{H}(t) = \hat{T} + \hat{V}(t) + \hat{W} $ is assummed to have the form of
kinetic energy: $$ \hat{T} = \sum_{s} \int d^{3}r \hat{\psi}_{s}^{\dagger}(\vec{r}) \left( -\frac{1}{2} {\nabla}^{2} \right) \hat {\psi}_{s}(\vec{r}) $$
one-particle potential: $$ \hat{V} = \sum_{s} \int d^{3}r \hat{\psi}_{s}^{\dagger}(\vec{r}) v(\vec{r} \; t) \hat {\psi}_{s}(\vec{r}) $$
two-particle potential: $$ \hat{W} = \frac{1}{2}\sum_{s}\sum_{s'} \int d^{3}r \int d^{3}r' \hat{\psi}_{s}^{\dagger}(\vec{r}) \hat{\psi}_{s}^{\dagger}(\vec{r}') w(\vec{r'}, \vec{r}) \hat {\psi}_{s}(\vec{r}') \hat {\psi}_{s}(\vec{r}) $$
At first I thought $ \hat{\psi}_{s} \equiv \langle \mathbf{r}_{s}| $, but it seemed wrong when I plugged in above formula, and calculated $ \langle \psi|\hat{T} | \psi \rangle $.
Actually, I found a similar question posted earlier (What exactly is $\hat{\psi}^\dagger(x)$? An operator or a function?), but it doesn't give a clear answer for that.
I want to know textbooks or articles about the operator $\hat{\psi}_{s}$, and how to operate it manually when it applied to a physical state $ |\psi \rangle $.
