I'm sure this is a silly question, but I can't figure out the answer. Current I'm reading chapter 4 in Weinberg's Lectures on Quantum mechanics. Earlier in the book, he asserts that unitary operators close to the identity look like
$$U \approx 1 + i T,$$ for some Hermitian matrix $T$. In this chapter, he deduces that generators close to the identity look like $$R \approx 1 + W,$$ where $W$ is real and skew-symmetric (and "infinitesimal") . So far, so good. This is just an intuitive way to think about the relevant Lie algebras.
He then says that the unitary transformation generated by an infinitesimal rotation $W$ is $$U(1 + W) \approx 1 + \frac{i}{2h} \sum w_{ij} J_{ij}.$$
I'm having trouble understanding this. Shouldn't the transformation generated by an infinitesimal rotation be some kind of rotation, and hence orthogonal? If so, why does the $i$ appear, bringing complex numbers into the picture?
A slightly different way to put this is, why does going from rotation to the associated infinitesimal rotation to the generated unitary transformation not give the original rotation back again?
Potato
  • 205
This is a difference of convention between mathematicians and physicists. Think of an antisymmetric real matrix. If you multiply it by i, you make it Hermitian instead of antiHermitian. Think of the J as having an i in it already because of physics conventions vs math conventions.
AHusain
  • 945
