-2
As explained in the answer to a question In the double slit experiment, using only one photon, will it create a diffraction pattern on an ultra sensitive screen?
During its path from the light source through the slits to the screen the light is delocalised, that is the photon doesn't have a position in the sense that macroscopic objects have a position. That's why it is able to pass through both slits at the same time.
Such an explanation couldn't explain fringes from single photons (over time) behind single edges. What is the explanation for the phenomenon that single photons produce fringes even behind single edges?
HolgerFiedler
  • 10,980
There are two different, yet completely equivalent, ways that I look at this problem.
The first, as noted in the comments and in many other places, is to us Huygen's principle. Why does Huygen's principle work? Because the assumed incident wave function is a plane wave. Huygen's principle is one way to create a plane wave, and then select what parts of it continue to propagate. The math then gives the diffraction pattern in a straightforward way.
The second equivalent way is to again start with an incident plane wave. By Fourier transform, this means that the transverse momentum of the wave function contains all frequency components. The slits, or half edge, or whatever else is in the way then serves as a frequency filter, only letting through the frequency components that correspond to the Fourier transform of their shape. Apply that filter in momentum space, and transform back to position space, and it all works out the same.
Now, the second method is more general, since you don't have to start with an ideal plane wave, but can instead model actual sources - you just have to do the FT, apply the transverse momentum filter, and transform back.
As an aside, thinking in terms of transverse momenta also makes looking at diffraction gratings, diffraction patterns in crystals, and many other similar problems much easier. Just be careful - nobody can hear you scream in reciprocal space...
Jon Custer
  • 7,986
