39
So Gerard 't Hooft has a brand new paper (thanks to Mitchell Porter for making me aware of it) so this is somewhat of a expansion to the question I posed on this site a month or so ago regarding 't Hoofts work.
Now he has taken it quite a big step further: http://arxiv.org/abs/1207.3612
Does anyone here consider the ideas put forth in this paper plausible? And if not, could you explain exactly why not?
11 Answers11
49
I only see these writings now, since usually I ignore blogs. For good reason, because here also, the commentaries are written in haste, long before their authors really took the time to think.
My claim is simple, as explained umpteen times in my papers: I construct REAL quantum mechanics out of CA like models. I DO have problems of a mathematical nature, but these are infinitely more subtle than what you people are complaining about. These mathematical problems are the reason why I try to phrase things with care, trying not to overstate my case. The claim is that the difficulties that are still there have nothing to do with Bell's inequalities, or the psychological problems people have with entangled states.
Even in any REAL QM theory, once you have a basis of states in which the evolution law is a permutator, the complex phases of the states in this basis cease to have any physical significance. If you limit your measurements to measuring which of these basis states you are in, the amplitudes are all you need, so we can choose the phases at will. Assuming that such CA models might describe the real world amounts to assume that measurements of the CA are all you need to find out what happens in the macro world. Indeed, the models I look at have so much internal structure that it is highly unlikely that you would need to measure anything more. I don't think one has to worry that the needle of some measuring device would not be big enough to affect any of the CA modes. If it does, then that's all I need.
So, in the CA, the phases don't matter. However, you CAN define operators, as many as you like. This, I found, one has to do. Think of the evolution operator. It is a permutator. A most useful thing to do mathematically, is to investigate how eigenstates behave. Indeed, in the real world we only look at states where the energy (of particles, atoms and the like) is much below the Planck energy, so indeed, in practice, we select out states that are close to the eigenstates of the evolution operator, or equivalently, the Hamiltonian.
All I suggest is, well, let's look at such states. How do they evolve? Well, because they are eigenstates, yes, they now do contain phases. Manmade ones, but that's alright. As soon as you consider SUCH states, relative phases, superposition, and everything else quantum, suddenly becomes relevant. Just like in the real world. In fact, operators are extremely useful to construct large scale solutions of cellular automata, as I demonstrated (for instance using BCH). The proper thing to do mathematically, is to arrange the solutions in the form of templates, whose superpositions form the complete set of solutions of the system you are investigating. My theory is that electrons, photons, everything we are used to in quantum theory, are nothing but templates.
Now if these automata are too chaotic at too tiny Planckian scales, then working with them becomes awkward, and this is why I began to look at systems where the small scale structure, to some extent, is integrable. That works in 1+1 dimensions because you have right movers and left movers. And now it so happens that this works fantastically well in string theory, which has 1+1 dimensional underlying math.
Maybe die-hard string theorists are not interested, amused or surprised, but I am. If you just take the world sheet of the string, you can make all of qm disappear; if you arrange the target space variables carefully, you find that it all matches if this target space takes the form of a lattice with lattice mesh length equal to 2 pi times square root of alphaprime.
Yes, you may attack me with Bell's inequalities. They are puzzling, aren't they? But please remember that, as in all no-go theorems that we have seen in physics, their weakest part is on page one, line one, the assumptions. As became clear in my CA work, there is a large redundancy in the definition of the phases of wave functions. When people describe a physical experiment they usually assume they know the phases. So, in handling an experiment concerning Bells's inequalities, it is taken for granted (sorry: assumed) that if you have measured one operator, say the z component of a spin, then an other operator, say the x component, will have some value if that had been measured instead. That's totally wrong. In terms of the underlying CA variables, there are no measurable non-commuting operators. There are only the templates, whose phases are arbitrary. If you aren't able to measure the x component (of a spin) because you did measure the z component, then there is no x component, because the phases were ill-defined.
Still, you can ask what actually happens when an Aspect like experiment is done. In arguments about this, I sometimes invoke "super determinism", which states that, if you want to change your mind about what to measure, because you have "free will", then this change of mind always has its roots in the past, all the way to time -> minus infinity, whether you like it or not. The cellular automaton states cannot be the same as in the other case where you did not change your mind. Some of the templates you use have to be chosen different, and so the arbitrary phases cannot be ignored.
But if you don't buy anything of the above, the simple straight argument is that I construct real honest-to-god quantum mechanics. Since that ignores Bell's inequalities, that should put the argument to an end. They are violated.
G. 't Hooft
  • 5,521
20
I'll briefly respond to these critics in the order I read them.
To Mitchell:
Since I reconstruct ordinary QM, I can make any state I like, including EPR states, GHZ states or whatever. At the level of the CA, most of these states will be blurred to some extent, and they contain complex phases that may seem to be physically meaningless. But, well, that's what you asked for. But read my answer to Ron as well. Now of course, your point is well taken, it would be nice if one could follow in great detail what actually happens when an EPR experiment is done. This is hard. It is easier to illustrate interference experiments at a more basic level. In principle, I see no obstacles at all.
To Ron:
If you really understood me 'perfectly', you would not have said that I am "putting [quantum mechanics] in". What I am putting in is the quantum states, see previous answer (as well as later explanations). You may continue calling me names for that. But what I get out is that these states obey Schroedinger equations. You could at best object that the Schroedinger equations will give the correct solutions of the CA equations only at integer time steps, but if these steps are as small as the Planck time, then that's good enough for any experiment.
So the CA obeys QM equations that would agree with conventional QM at integer time steps, or equivalently, as long as you limit the separations of your energy levels to being amounts much less than the Planck energy. Good enough for any of today's experiments. Well if you still think you understood me perfectly, please go back to sleep.
To Mitchell's next statements:
Those random number generators are deterministic, like everything in my theory. So their outcome does depend on the past, whether you like it or not. The mapping from the CA states to the template states used in QM implies that any modification in your random number program will end up describing the scenery in terms of totally defferent CA states.
Then, as I has already stated, the phases of the template states (IN THE CA BASIS, OF COURSE!) are unphysical, and this means that, as in real qm, you can't specify the outcomes of measurements of two non-commuting operators at the same time. Yes, if you forget to look carefully at the CA states, it looks like cheating, like finetuning the initial conditions, but it is not; since you can't move from one universe into another, the initial conditions must be that the CA is in one precisely defined mode at all times. This means that, at all times, the universe is in one exactly defined "quantum" state. It is the state in which the automaton's observables are diagonalised and are in one eigen state only. Any "superposition" of two or more of such states is not ontological anymore. But, what seems to confuse most of you, is that nevertheless the Universe's wave function obeys a linear Schroedinger equation. Superpositions are allowed in the 'template' states ...
"... these models, though quantum, aren't counterexamples to Bell" ? So, I got through to you halfway. My models indeed are quantum. All I have to convince you of next, is that any quantum state is admissible as a probabilistic description of the CA, so there is no obstacle against creating the initial conditions of a Bell experiment, and remember that the template states are complicated superpositions of CA states again, so these indeed lead to apparent interference phenomena.
Ron makes the remark that my "assumption is completely unjustified" that one can take superimposed states of the CA. Please Ron, think again. The "superpostion" is nothing but a probabilistically smeared state, and because the CA merely permutes its ontological states, this probabilistically smeared state evolves in line with both qm and probability theory. So there is no objection at all ! And this allows me later to go to another basis, that of the templates, any way I please !
What confuses him is, that at the level of the CA all of this is so trivial. What makes my theory non trivial is the subsequent transformations in Hilbert space. It's like shouting that the emperor doesn't have any clothes on, please wake up.
"... If you don't know which basis you are in, you describe this lack of knowledge by a probability distribution on the initial state, not by probability amplitudes", he says. Wait a minute: why not? I admit that the phases of the amplitudes there don't seem to do much, but that's deceptive; the phases allow me to make my mathematical transformations. It's a trick, yes, but a very handy one! And AFTER these transfomations are done, one DOES get quantum superpositions out.
I have explained why I want free theories to start from. The CA models I had used previously had interactions that are so strong that doing math with them gets to become too complicated. So, I start with non-interacting systems. Leave the (deterministic) interactions for later.
The world sheet lattice is not conformally invariant. You have a point there, and indeed, I now think that one has to replace that lattice with a continuum at some stage; I do not think this changes things very much, the lattice can be taken as tiny as one wishes.
This is also my answer to Chris: "Where is the mathematics behind all of this?" He seems not to like the lattice cut-off of on the string world sheet. Well, we commit such crimes in all our quantum field theories: give them a lattice cut-off and then send the lattice to the continuum. I admit that I haven't explored yet how this goes in practice in string theory. The commutation rules and constraints have to be taken into account carefully. What I observed is that the size of the world sheet lattice doesn't matter; the target space lattice keeps a fixed lattice mesh size.
Chris thinks I am doing metaphysics. Well, I always thought that much of string theory is metaphysics, where one jumps from one conjecture to the next. I found it to be a great relief to discover that string theory generates a well-defined lattice in target space. Let me add that in the paper I put the lattice in Minkowski space, but this might not be right, or at least not useful. It may well be better to keep Minkowski time continuous.
Ron also remarked that "the worldsheet is totally nonlocal in space time". What makes him say that? If you have a bunch of closed strings, and if these behave classically when considered on a space(time) lattice, then that's local in the classical sense. Of course, strings spread a bit, but only at Plankian scales.
G. 't Hooft
  • 5,521
15
(I apologize if this comment pops up twice, I don't quite understand how it works here)
To Ron:
Don't worry about the authority issue, It's fine with me if you don't take my authority for granted. But it helps if you look at my papers more carefully.
Back to the issue: remember that the true, "ontological" state of the universe is assumed to be one single mode of the CA. No superpositions, ever. But then, we make a basis transformation. We've learned this when doing quantum mechanics, so we do it all the time. All I ask is: consider the CA as a system in a special basis, call that the "ontological" basis. Now consider some transformation to a different basis. The simplest such transformation is a (discrete or continuous) Fourier transformation, but in the real world, probably, the transformations needed will be much more complicated. After you've done that, you'll find that the time evolution in that basis, like in any basis, is described by a Schroedinger equation. But, because of these transformations, all states you will encounter from now on will be quantum superpositions of CA states. This does NOT mean that now the universe is in a superposition, it simply means that the states we use, I call them templates, are superpositions. Well, this means that if you transform back, the CA states of the universe are superpositions of our template states.
This is how superpositions come about in my theory.
You argue: "Suppose you tell me ...", no, I didn't tell you that. You are exactly repeating the basic error people commit when arguing away hidden variable theories. This is what I mean when I claim that what's wrong with Bell like arguments is on page one, line one, the assumptions. The difference between an electron with spin up and an electron with spin down is only one bit of information, also for the CA. Ontologically, the CA is never in a superposition. Our description of it is, because of our lack of knowledge.
Only after you measured the spin, up, down, sideways, whatever, the macroscopic measuring device is in a CA state that is pronouncedly different depending on the outcome. But also when you rotated the measuring device to observe spin in a different direction, you made a colossal change in the CA configurations.
Maybe the best way of phrasing the answer to your question is: the rho_1 and the rho_2 differ by many bits of information due to the fact that your measuring device is different in these two worlds, but by only one bit of information that corresponds to the outcome of the measurement. Actually, rather than rho_1 and rho_2, I would be inclined to give you set_1 and set_2, where these sets contain many ontological values of the CA. If you decide to switch the orientation of your measuring device, set_1 and set_2 have no element in common. There is one bit of information in set_1 that gives the outcome of the experiment, and one bit in set_2 giving the outcome of the experiment there. There is no overlap, but, by ignoring the environment, our 'template states' which are referring to the electron only, are superimposed. The phases of these superpositions are meaningless, because set_1 and set_2 do not overlap.
Too few CA states to factor big numbers ... bravo, this the one point where my theory makes a prediction, and I mentioned this in some of my papers: my prediction is that there will be difficulties to fabricate the 'perfect' quantum computer. You know that the quantum computer is based on two conflicting requirements of its physical system: you need the absence of interactions in order not to disturb the quantum coherence of states, while interactions will be needed to read off what the states are. My prediction is that the CA underlying our physical world will generate interactions that cannot be tuned any sort of way, so the space between Scylla and Charybdis is finite, and will generate failures in the quantum computer.
G. 't Hooft
  • 5,521
14
To Ron:
The difference between the automaton states representing a filter in one direction, and a filter that is slightly rotated, is huge, because these systems are macroscopic.
Now you might wonder however, whether, in principle, we could be dealing with a device that rotates the filter in response to the outcome of the measurement of some quantum object. like the spin of some other electron. In that case, a difference in what might have been a single cell in the automaton, has grown into a macroscopic deviation (compare a classical mechanical system with a positive Lyaponov exponent). But by the time we are able to measure the electron with a rotated filter, the difference has become macroscopic.
A lot of information to hide in the vacuum? Not at all, if the vacuum can be imagined as a CA in a chaotic mode, and if indeed the meshes of the space-time lattice are of the order of the Planck scale. You can put huge amounts of information there.
Please remember that, if you superimpose two states of, say, an electron, you are not really superimposing two states of the automaton, but you are superimposing two states of the templates you are using, in order to get the best template to describe the new situation, which in reality is an automaton in a state that differs from both others; it isn't a superposition. This is what I tried to explain in my paper on the "Collapse of the wave function and Born's rule". I found that we have to work with sets that represent allowed states of the automaton. Since we do not know exactly the initial state, we can use the rule that the probabilities are proportional to the sizes of the sets. This is what I concluded when using density matrices to see how states get smeared due to decoherence effects in the environment. A system interacts weakly with its environment, and smears its states a bit. When we do a measurement, we ignore the states of the environment.
G. 't Hooft
  • 5,521
12
To Ron:
Maybe we are getting somewhere. You say:
"Taking a formal Hilbert space, asserting that one has an unknown ontic state, and then formally defining operators is not justified..."
Wait, isn't that what we always do in science in general and in QM in particular? We concoct a model, conjecture an evolution operator, and ask how any initial state evolves? My model just happens to be a CA, my evolution operator just happens to have only ones and zeros, and that only in a very specially chosen basis, and, well, who knows what nature's ontic state is?
I find that if the universe starts out in just any CA state, it continues to be in exactly one CA state. This is all I do. There's a superselection rule: you can't hop from one CA mode into another.
There is some freedom in choosing the eigenstates of H. If a system has a discrete time variable, you can keep the eigen values within an interval. The only constraint delivered by the CA theory is that the levels form sets of levels such that within each set they are equally spaced (they are the discrete harmonic oscillators, or more precisely: periodic sub systems).
My earlier CA models indeed had perturbation expansions where convergence was an issue. In attempting to get models that I can use to answer your (and my own!) questions, I was demanding too much. But I don't think I understand exactly what you try to say in your last paragraph. There is the vacuum state, a formal superposition of many CA states whose coefficients are stationary, and there are perturbations around that. Earlier models had the problem that the excitations above the vacuum state hardly look like particles, as not only we have no Lorentz invariance, but not even Galilei invariance, which was a nuisance, although it has nothing to do with the real quantum issues addressed here. My latest ideas about superstring theory are much better in this respect. My work on that is not finished, but rotation invariance and Lorentz invariance seem to be quite possible here.
G. 't Hooft
  • 5,521
11
In another blog I posted the explanation given below; I edited it slightly more. Apologies for the repetitions. Please react.
The idea of my latest paper is simple. I experienced in several blogs now that most people refuse to go with me all the way. I'll give my argument step by step and you may choose where you want to step out. I should add that some of the steps are still conjectural, not all the math has been worked out as clearly as I would like. Most importantly, as was mentioned in the paper, these results are independent of arguments such as Bell's inequalities. Of course I am worried about them, but below I just sketch a train of arguments where I don't see any basic mistake.
But this is the picture I get.
  1. Consider superstring theory, in its original, completely quantized version. Many people believe it might have something to do with the world we live in. It has interesting low energy modes that show some resemblance with what happens in the Standard Model: fundamental fields for particles with soin 0, 1/2 and 1, as well as gravitons for the gravitational field, and gravitinos. The theory is not universally accepted, but it is an interesting model with many features that look like our world. Certainly not obviously wrong, and certainly very much quantum. There is a Hilbert space of states. I only use it as a model to illustrate my ideas. But step out here if you want.
  2. Temporarily, I now have to put the world sheet on a (lightcone) lattice. This is a nuisance, and I quickly want to send this lattice to the continuum limit, but not all math has been straightened out. Step out if you want.
  3. The transverse coordinates of the string form a simple integrable quantum field theory on the string world sheet. This integrable system has left-movers and right-movers, forming quantum states, the string excitations. Now I discovered a unitary transformation that transforms the basis of this Hilbert space into another basis. In QM, we do this all the time, but what is special in the new basis is that it is spanned completely by a set of left-movers and right-movers that are integer valued, in units whose fundamental length is 2 \pi \sqrt(\alpha\prime). Thus, we have operators taking integer values, and they are all commuting. What's more, they commute at all times. The evolution operator here translates the left movers to the left and the right movers to the right. Intuitively, you might find that the result is not so crazy: these integers are of course related to particle occupation numbers in quantum theory. I still have Hilbert space, but it is controlled by integers. If you don't like this result, please step out.
  4. Do something similar to the fermions in the superstring theory. They can be transformed into Boolean variables using a Jordan-Wgner transformation. The superstring theory of course has supersymmetry on the world sheet. That does not disappear, but does become less conspicuous. Also the fermions are tranversal. The Boolean variables also commute at all times. Next stop.
  5. Realize that, if Nature starts in an eigen state of these discrete operators, it will continue to be in such an eigenstate. There is a superselection rule: our world can't hop to another mode of eigen states, let alone go into a superposition of different modes. Thus, if at the beginning of the universe, we were in an eigenstate, we are still in such an eigenstate now. Step out if you want.
  6. I can add string interactions. My favorite one is that strings exchange their legs if they have a target point in common. This is deterministic, so the above still applies. In all fairness, I should add that I have not worked out the math here completely, there are still unclear things here. This is a stop where you may get out.
  7. Rotations and Lorentz transformations. To understand these, we need to know the longitudinal coordinates. The original, completely quantized superstring tells you what to do: the longitudinal coordinates are fixed by solving the gauge constraints (both for the coordinates and the fermions) . The superstring has only real number operators, of course non-commuting. This step tells us that only 10 dimensions work, and fixes the intercept a. Don't like it? Please step out.
  8. What I have here is a Lorentz invariant theory equivalent to the model generated by the original superstring theory, but acting like a cellular automaton. It IS a cellular automaton. Any passengers left?
G. 't Hooft
  • 5,521
10
EDIT: Explanation in light of 't Hooft's answers
I have been getting downvotes, possibly because people percieve a disconnect between the comments I made in response to 't Hooft's answers, and the content of this answer. The two sets of statements are not incompatible.
I would like to say where I agree with 't Hooft:
  • I don't think hidden variables are impossible.
  • I do think that it might be possible to reproduce something approximately like QM from something which is exactly a classical automaton. (I give it a 50% chance of working, I can't do it yet, but it looks possible, and if it is possible, I give it an 80% chance of being true, therefore overall, I give a 40% chance to this scenario.)
  • I don't think other people's criticism of his program is valid, because people tend to believe hidden variables are just plain impossible, and I don't see a proof. The proofs are for local hidden variables or for naive hidden variables.
My criticism is not of the general program, it is of the precise implementation, as detailed in this paper and previous ones. The disagreements come from the mismatch between the Hilbert space that t'Hooft introduces without comment, as a formal trick, and classical probability space:
  • 't Hooft considers the space of all possible superpositions of states of a classical automaton, plus an exponentiated Hamiltonian that reproduces the automaton behavior on a discrete time. This Hilbert space is formal, not emergent, it is a trick for rewriting probability distributions.
  • 't Hooft says that so long as the basis states evolve according to permutation, there are never any superpositions in the global states. But he then goes on to discuss operators whose eigenvectors correspond to definite states of interior subsystems, and he claims that it is possible to prepare superpositions of these subsystems using these operators. The process of measuring these operators does not, as I see it, necessarily have a clear meaning in terms of the no-superposition global states, and it does not correspond to a classically allowed operation on the CA involved.
If it is possible to get quantum mechanics from CA, then I agree with nearly every intuitive statement 't Hooft makes about how it is supposed to happen—including the "template" business, and the reduction to Born's rule from counting automata states (these intuitions are horrendously vague, but I don't think there is anything wrong with them), I only disagree with the precise stuff, not the vague stuff (although if QM does not ever emerge from CA, the vague stuff is wrong too, in that case, I would just be sharing 't Hooft's wrong intuition). There is a slight difference in intuition in that I think that the violation of Bell's theorem comes from nonlocality not from superdeterminism, but this is related to the precise implementation difference in the two approaches. I will focus on the disagreements from now on.
Probability distributions on CA
Consider a CA where we know the rules, we know the correspondence between the CA and the stuff we see, but we don't know the "ontic state" (meaning we don't know the bits in the CA). We make a probability distribution based on our ignorance, and as we learn more information from observation, we make a better and better probability distribution on the CA. This is the procedure in classical systems, it can't be fiddled with, and the question is whether this can ever look like quantum mechanics at long distances.
Luboš Motl asks the fair question—what is a noncommuting observable? To describe this, consider a system consisting of $2N$ bits with an equal number of zeros and ones. The measurement $A$ returns the parity of the number of $1$'s in the first $N$ bits, and performs a cyclic permutation one space to the right on the remaining $N$ bits. The measurement $B$ returns the parity of the number of $1$'s in the bits at even-numbered positions (it's a staggered version of $A$) and permutes the odd bits cyclically. These two measurements are noncommutative for a long, long time, when $N$ is large, you need order $N$ measurements to figure out the full automaton state.
Given a full probability distribution on automaton states $\rho$, you can write it as a sum of the steady state (say uniform) distribution and a perturbation. The perturbation behaves according to the eigenvalues of the linear operator that tells you how probabilities work, and in cases where you have long-wavelength measurements only (like the operators of the previous example), you can produce things that look like they are evolving linearly with noncommutative measurements that vaguely look like quantum mechanics.
But I can't find a precise limit in which this picture reduces to QM, and further, I can't use 't Hooft's constructions to do this either, because I can't see the embedding of Hilbert space precisely in the construction. It can't be a formal Hilbert space as large as the Hilbert space of all superpositions of all automaton states, because this is too big. It must be a reduction of some sort of the probability space, and I don't know how it works.
Since 't Hooft's construction fails to have an obvious reinterpretation as an evolution equation for a classical probability density (not the Hamiltonian—that has an obvious interpretation, the projections corresponding to measurements at intermediate times), I can't see that what he is doing is anything more profound than a formal trick, rewriting QM in a beable basis. This is possible, but it is not the difficult part in making QM emerge from a classical deterministic theory.
If you do it right, the QM you get will at best only be approximate, and will show that it is classical at large enough entangled systems, so that quantum computation will fail for large quantum computers. This is the generic prediction of this point of view, as 't Hooft has said many times.
So while I can't rule out something like what 't Hooft is doing, I can't accept what 't Hooft is doing, because it is sidestepping the only difficult problem—finding the correspondence between probability and QM, if it even exists, because I haven't found it, and I tried several times (although I didn't give up, maybe it'll work tomorrow).
Previous answer
There is an improvement here in one respect over previous papers—the discrete proposals are now on a world-sheet, where the locality arguments using Bell's inequality are impossible to make, because the worldsheet is totally nonlocal in space time. If you want to argue using Bell's inequality, you would have to argue on the worldsheet.
't Hooft's models in general have no problems with Bell's inequality. The reason is the main problem with this approach. All of 't Hooft's models make the completely unjustified assumption that if you can rotate a quantum system into a $0$-$1$ basis where the discrete time evolution is a permutation on the basis elements, then superpositions of these $0$-$1$ basis elements describe states of imperfect knowledge about which $0$-$1$ basis is actually there in the world.
I don't see how he could possibly come to this conclusion, it is completely false. If you don't know which basis you are in, you describe this lack of knowledge by a probability distribution on the initial state, not by probability amplitudes. If you give a probability distribution on a classical variable, you can rotate basis until you are blue in the face, you don't get quantum superpositions out. If you start with all quantum superpositions of a permutation basis, you get quantum mechanics, not because you are reproducing quantum mechanics, but because you are still doing quantum mechanics! The states of "uncertain knowledge" are represented by amplitudes, not by classical probabilities.
The fact that there is a basis where the Hamiltonian is a permutation is completely irrelevant, 't Hooft is putting quantum mechanics in by hand, and saying he is getting it out. It isn't true. This type of thing should be called an "'t Hooft quantum automaton", not a classical automaton.
The main difficulty in reproducing quantum mechanics is that starting with probability, there is no naive change of variables where the diffusion law of probability ever looks like amplitudes. This is not a proof, there might be such effective variables as far as I know, but knowing that there is a basis where the Hamiltonian is simply a permutation doesn't help in constructing such a map, and it doesn't constitute such a map.
These comments are of a general nature. I will try to address the specific issues with the paper.
In this model, 't Hooft is discussing a discrete version of the free-field string equations of motion on the worldsheet, when the worldsheet is in flat space-time. These are simple $1+1$ dimensional free field theories, so they are easy enough to recast in the form 't Hooft likes in his other papers (the evolution equation is for independent right and left movers. The example of 4D fermions 't Hooft did many years ago is more nontrivial).
The first issue is that the world sheet theory requires a conformal symmetry to get rid of the ghosts, a superconformal symmetry when you have fermions. This gives you a redundancy in the formulation. But this redundancy is only for continuous world-sheets, it doesn't work on lattices, since these are not conformally invariant. So you have to check that the 't Hooft beables are giving a ghost-free spectrum, and this is not going to happen unless 't Hooft takes the continuum limit on the world-sheet at least.
Once you take the continuum limit on the worldsheet, even if the space-time is discrete, the universality of continuum limits of 2D theories tells you that it doesn't make much difference—a free scalar which takes discrete values is fluctuating so wildly at short distances that whether the target space values are discrete or continuous is irrelevant, they are effectively continuous anyway. So I don't see much point in saying that leaving the target space discrete is different from usual string theory in continuous space, the string propagation is effectively continuous anyway.
The particular transformation he uses is neither particularly respectful of the world-sheet SUSY or of the space-time SUSY, and given the general problems in the interpretation of this whole program, I think this is all one needs to say.
Řídící
  • 6,847
Some thoughts on this topic.
1) For the newcomer to this topic: There are three 2012 papers by Gerard 't Hooft that you need to read. 1204.4926 maps a quantum oscillator onto a discrete deterministic system that cycles through a finite number of states. 1205.4107 maps an integer-valued cellular automaton (CA) onto a free field theory made out of coupled quantum oscillators. Finally, 1207.3612 adds boolean variables to the CA in order to obtain fermionic fields.
2) I find what Gerard 't Hooft says, about how local CAs might get around Bell's theorem, to be quite unconvincing. The theorem says it's impossible. The "superdeterminism" loophole should require completely unrealistic finetuning of the probability distributions over CA states (the distributions that correspond e.g. to distinct settings of measurement apparatus in an EPR experiment). It's not even clear to me that such finetuning is possible in his setup. The novelty of his constructs, and his particular language of "templates", etc, means that it's not immediately obvious how to bring what he does and says, into correspondence with the established theorems. But at the current rate of engagement with his ideas, I expect that by the end of the month, we should have this aspect sorted out.
3) "The Gravity Dual of the Ising Model" would clearly be important for any attempt to get quantum gravity out of quantum cellular automata. The gravity dual here lives in AdS3, and AdS3 appears to have an unusual universality as far as string theory is concerned. It might be a factor of the near-string geometry in any geometrical background, for example. (I would try to be more precise but I find the literature hard to get into. But here is a short review.) There may be a reformulation of string theory in terms of a quantum CA where the cells are the "string bits". (Lubos Motl's early work ought to be relevant here!)
4) "Clifford quantum cellular automata" are a type of quantum CAs which map onto a classical CA in a way very similar to 't Hooft's mapping - see section II.B.1 of that paper. They ought to be relevant for attempts to understand and generalize the mapping in his 2012 papers, e.g. to the case of interacting fields.
5) 3&4 together offer an alternative to 2. That is, one might hope to get a quantum bulk theory from a classical CA on the boundary, that is equivalent to a quantum CA holographically dual to the bulk theory. Because of the nonlocality of the boundary-to-bulk mapping, it's much less obvious than before (to me, anyway) that you can't get Bell violations in the bulk.
6) Another place where contact might be made with existing research, is via consistent histories. Suppose you defined the histories in terms of the quantum observables whose eigenstates are employed in 't Hooft's oscillator mapping, while also using the same timestep. The CA is then a coarse-graining of the quantum evolution.
7) Finally, I'll put in a plug for my favorite way to get realism from QM, and that would be to treat tensor factors as the "cells". If we denote a two-dimensional Hilbert space as "H", then the state space of a cell (the set of possible states) might be H + H^2 + H^3 + ... If you consider the dynamics available to a CA like this, it's a lot more powerful, and my guess is that the simplest deterministic model of realistic QM would look more like that sort of CA, rather than like a CA with boolean or scalar cell-values.
I think that physicists will generally ignore Prof. 't Hooft's research on CA superstring determinism until at least one dramatic, new testable prediction arises. I have suggested that the -1/2 in the standard form of Einstein's field equations should be replaced by -1/2 + dark-matter-compensation-constant. My guess is that CA superstring determinism is highly compatible with this new dark matter approach. If not, then CA research needs to do something else dramatic, such as give a testable explanation of the space roar or the GZK paradox.
In response to the downvotes: 1) Please note that all of the conversation above has been using no mathematics... this is turning into a philosophical argument and should be closed as such. 2) Explain the reasoning for these downvotes. This thread seems to be becoming very biased.
It has as much plausibility as the other papers, because it depends on the other papers.
There are two big problems I see:
1) There are left-movers and right-movers, and there is a lattice cut-off. The cut-off does not affect the particle dispersion law: all modes with momentum below the Brillouin zone move exactly with the (worldsheet) speed of light. There is no direct interaction yet. We did not (yet) consider boundary conditions, so the string has infinite length. Thus, apart from the lattice cut-off in the world sheet, this is a quantum string. After the transformation described in Ref. [9], the space-time lattice disappears and now seems to look like a continuum.
-- This was an excerpt from the paper. It talks about "strings with infinite length" and ignores the lattice cut-off to describe the string. Where is the mathematics behind all of this?
2) The philosophy used here is often attacked by using Bell’s inequalities[1]—[3] applied to some Gedanken experiment, or some similar “quantum” arguments. In this paper we will not attempt to counter those...
-- The paper does not try to answer the problem with Bell's inequalities AT ALL. The point of the paper is to use the math to say something (i.e. interpretation) about String Theory, but such an interpretation seemingly goes against the Bell's inequalities.
Anyway, the paper tries to make String Theory resemble a discrete system of "bits of data", the 'resemblance' being made by mathematics, and then studying the discrete system to try and say something about the classical-versus-quantum interpretation of String Theory. It is meta-physics at this point.
(I clarify that this is just my thought after reading the paper, which is all that the question is asking for... even though I could be misunderstanding everything and this work turns into a Nobel Prize)
Chris Gerig
  • 2,798
My understanding of 't Hooft's intent is to restore objective locality at a more fundamental level that Dirac called "the substratum". 't Hooft hopes that Bell's theorem is obeyed there and that orthodox quantum theory with its linear unitary conservation of qubits is an emergent collective phenomenon. I personally think he has it upside down and that classical physics (cellular automata etc.) is emergent out of the quantum level. However, until the alternatives can be Popper falsified the whole business is "not even wrong" speculation - not that I think it is bad to speculate - to the contrary.
