Approach 1)Since a dielectric alters only the charge on the plates, i.e. The charge decreases as the dielectric moves inside the capacitor and then finally after reaching the middle position charge on plate increases.
2)Therefore current must flow from the positive end to the negative one i.e.A to B.
Are the above arguments correct?
given
CASE 1 The dielectric slab is moved through the capacitor t=0 completely outside at t=t1 completely inside and at some time t=t2 it has passed through the capacitor
CASE 2 the dielectric is simply inserted between the plates
Disclaimer not a homework question, a question from a recent exam.
Sher
I believe your reasoning is partially correct, there is just one point that is unclear.
You can assume that the insulating plate is a better dielectric than air. Inserting the plate, then, would increase the capacitance (the insulator polarizes i.e. polar molecules align with the field, and effectively reduces the electric force between the plates with their own contribution of electric force in the opposite direction). Since capacitance increases, the ability to store charge increases (it takes more charge to cause the same voltage across the plates of the capacitor since the electric force/electric field is weaker and the "voltage" is the electric field with distance taken out of account) and so more charge will flow onto the plates.
Given all that, a conventional current will flow from positive to negative - from A to B, just like you said. What seems slightly ambiguous to me is whether or not the insulator passes all the way through or if it is simply inserted in between the plates. If it is simply inserted, current will only flow from A to B. But if it passes straight through, then the capacitance will decrease after the half way point and extra charge difference between the plates will cause a stronger electric force/electric field, thus a higher voltage between the plates, than was originally supplied. Charge will then flow in the opposite direction - from B to A.
Note: I usually prefer to talk in electric force in my answers as opposed to electric field. This helps me remember that the "field" that everyone talks about is just the electric force, without taking the charge it acts on into account. Electric field is used because you don't know what the charge that feels a force will be, but it "muddies the waters" when talking like this because electric field doesn't sound like electric force.
Insertion of a dielectric does not directly affect the charge on the plates (unless you insert it slowly); rather, it decreases the electric field between the plates. As the electric field and the potential are related by $V = Ed$, the potential difference across the capacitor also decreases ($d$ remains constant; $E$ decreases, therefore $V$ decreases).
Case 1: Capacitor is fully charged before insertion
Initially, the potential difference across the capacitor would be equal to the E.M.F of the battery. As the insertion of dielectric reduces the potential difference across the capacitor, a current is driving in the circuit such that the potential drop across the capacitor equals the E.M.F. If the potential drop across the capacitor has to increase, the charge on the plates must increase; therefore, the current flows in the direction which increases charge on the capacitor. This direction is from $A$ to $B$.
Case 2: Capacitor is not fully charged; on its way to being fully charged
Initially, the potential difference across the capacitor is less than the E.M.F of the battery. When the dielectric is inserted, the potential difference drops. For the reasons mentioned in the previous case, the current will flow in such a way that the charge on the capacitor increases. This direction is from $A$ to $B$.
Case 3: Capacitor is overcharged; potential drop across the capacitor is more than the E.M.F
Initially, the potential difference across the capacitor is more than the E.M.F. This would cause the current to charge the battery (initial current is from $B$ to $A$). After the dielectric is inserted, the potential drop across the capacitor decreases. There are two sub-cases in this situation.
  • The new potential drop is smaller than the E.M.F
    The current reverses. The current flows such that the potential drop across the capacitor increases (tries to fully charge the capacitor). The direction of current is from $A$ to $B$.
  • The new potential drop is greater than the E.M.F
    As the potential drop across the capacitor is greater than the E.M.F, the current continues to flow from $B$ to $A$.
Yashas
  • 7,257
Assume that the potential difference across the capacitor does not change; it stays equal to the emf of the cell.
Basically I am assuming the resistance of the wires and cell are relatively small and so is the time constant of the circuit.
$A$ has a positive charge and $B$ has a negative charge before the dielectric is inserted.
As the dielectric is inserted the capacitance increases and so more charge is stored on the plates.
$C\uparrow V \Rightarrow Q\uparrow$
The amount of positive charge on plate $A$ must increase and there will also be more negative charge (less positive charge) on plate $B$.
The (conventional - movement of positive charges) current must flow from $B$ along the wires and through the cell to $A$.
The current will reverse as the dielectric leaves the capacitor; its capacitance decreasing and the amount of charge stored being less.
Farcher
  • 104,498
